Hello all,
First Question, New user to FEZ Panda II.
I want to get 4 PWM output from FEZ Panda with different frequencies. If i use only one pin it works fine. If i use 4 pins with same frequency it works but when i want different frequencies on all PWM pins. Everything is messed up. i get interference on pins and nothing on which i set different frequency.
How can i use 4 PWM Pins with different frequencies.
Like this create interfearence or no output;
namespace FEZ_Mini_Application1
class Program
PWM L1 = new PWM((PWM.Pin)FEZ_Pin.PWM.Di5);
PWM f1 = new PWM((PWM.Pin)FEZ_Pin.PWM.Di6);
PWM f2 = new PWM((PWM.Pin)FEZ_Pin.PWM.Di8);
PWM f3 = new PWM((PWM.Pin)FEZ_Pin.PWM.Di9);
L1.SetPulse(50000,44500);
f1.SetPulse(5000000,25000);
f2.SetPulse(100000,44500);
f3.SetPulse(25000,44500);
Thank you all
