Has anyone developed a multiline textbox for Glide 1.0.3?
The keyboard has 3 line input, but not a 1:1 with the resulting graphics object.
Ian
Ian
A year and a half passed since the original post, any updates on this topic?
Thanks.
However, TextBlock differs from TextBox, both in presentation (no border) and in behaviour (OpenKeyboard event does nothing with a TextBlock).
[quote=“andre.m”]
the good thing as a software developer you can write whatever function you want ;)[/quote]
Yeah I figured out that already.
Is there a formal specification on what controls are there and what do they do and how do they behave?
I suppose Glide.Display.DisplayObject should contain Text field like its elder brother System.Windows.Forms.Control does.
I mean, is there a design document that says “control X is for displaying data and soliciting user input, it has borders such and such, whereas control Y is just for displaying text and has no borders”? These links provide no insight on that.
Alright!
In order to have a multiline TextBox one has to add MultiLine property to it and rewrite Render to accept it:
in Glide\UI\Text\TextBox.cs:
/// <summary>
/// Specifies that the control is multiline
/// </summary>
public bool Multiline { get; set; }
public override void Render()
int x = Parent.X + X;
int y = Parent.Y + Y;
ushort alpha = (Enabled) ? Alpha : (ushort)(Alpha / 3);
Parent.Graphics.Scale9Image(x, y, Width, Height, _TextBox, 5, 5, 5, 5, alpha);
if (Multiline)
var tex = Text;
Parent.Graphics.DrawTextInRect(text, x + leftMargin, y + 3 , Width - (leftMargin * 2), Height, TextAlign, FontColor, Font);
Parent.Graphics.DrawTextInRect(ShortenText(Text), x + leftMargin, y + ((Height - Font.Height) / 2), Width - (leftMargin * 2), Height, TextAlign, FontColor, Font);
The if clause is added, with the false branch being the default/out-of-the-box (single line) behavior.
I’m assuming that no one really wants a multiline password box xD
I’m having an issue though.
In Glide Designer I’ve set font to Droid Sans Regular, 14pt (Font=“5”), which seems to be the same font the KeyboardText object uses internally (droid_reg14, ordinal 5 in FontManager.FontType enum), however the controls are rendered in strikingly different typefaces. Compare:
