I am about to buy the dev kit for an upcoming project. I was wondering if the serial library would allow for multidrop ( 9th bit set, stick parity?) and 485 direction switching.
Thanx
Andre Baird
Thanx, this will help. Which CPU is currently used on the Chipworkx?
BRG
Andre
Thanx
OK, I checked the datasheet and the uart on that is pretty clever. All you need for RS485 is to set a register bit and its done automatically. There is also a specific register to send an address byte with 9th bit set. ;D
