So, I’ve got 2 SPI devices (LCD and Flash Memory) on SPI3 of a G120. I’ve implemented a BusManager class to change configs based on the device being accessed, but if the clock speed of the configs are different I get erratic behavior. I initialize the LCD first @ 10MHz, then when the Flash is selected, I change to a config where the clock speed is 25MHz. This causes the Flash methods to return invalid data. I have tried to destroy the SPI device first and recreate it if I am switching config, but that did not work either. Any ideas are appreciated!
Below is the bus manager class.
    public class SpiBusManager
        private SPI _spi;
        private Hashtable _configurations;
        private object _lockObject = new object();
        public SpiBusManager()
            _configurations = new Hashtable();
        public void AddConfiguration(string device, SPI.Configuration config)
            if (!_configurations.Contains(device))
                if (_spi == null)
                    _spi = new SPI(config);
                _configurations.Add(device, config);
        public void WriteRead(string device, byte[] write, byte[] read)
            lock(_lockObject)
                if (_configurations.Contains(device))
                    _spi.Config = (SPI.Configuration)_configurations[device];
                    _spi.WriteRead(write, read, 0);
        public void WriteRead(string device, byte[] writeBuffer, byte[] readBuffer, int startReadOffset)
            lock (_lockObject)
                    _spi.WriteRead(writeBuffer, readBuffer, startReadOffset);
        public void WriteRead(string device, byte[] writeBuffer, int writeOffset, int writeCount, byte[] readBuffer, int readOffset, int readCount, int startReadOffset)
            lock (_lockObject)
                    _spi.WriteRead(writeBuffer, writeOffset, writeCount, readBuffer, readOffset, readCount, startReadOffset);
        public void Write(string device, byte[] writeBuffer)
            lock (_lockObject)
                    _spi.Write(writeBuffer);
