Hi guys
here is my Helper Class for the Mountaineer on board RGB Led:
https://mountaineerboardled.codeplex.com/
Hope this will be usefull to all of you.
Regards
AlbeNET
Hi guys
Regards
AlbeNET
Nice job! I saw your comment about adding Gadgeteer driver for the led. Keep in mind that mainboard class uses one of the RGB components, so you will not be able to use all three.
Currently i’m using the RGB led WITH Gadgeteer code… and seems running…
