I upgraded Mountaineer Ethernet mainboard to latest firmware and SDK (Release 4.3.1 beta 3) and would like to test simple example of Web Service that allows to remotely control the on-board LED (from Playing with Mountaineer Ethernet Mainboard | Integral Design).
When I call web event to handle requests on led path (http://10.230.17.212/led?mode=on) I get error in Visual Studio:
Using mainboard The Mountaineer Group MountaineerEth version 1.0
Web server started at http://10.230.17.212:80/
Program Started
A first chance exception of type ‘System.IndexOutOfRangeException’ occurred in Gadgeteer.WebServer.dll
The thread ‘’ (0x6) has exited with code 0 (0x0).
The program ‘[2] Micro Framework application: Managed’ has exited with code 0 (0x0).
Code:
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
using Gadgeteer.Modules.Mountaineer;
namespace HelloMountaineer
public partial class Program
private GT.Timer tmrBlink;
private bool isLedOn;
ethernetForMountaineerEth.NetworkUp +=
new GTM.Module.NetworkModule.NetworkEventHandler(ethernetForMountaineerEth_NetworkUp);
ethernetForMountaineerEth.UseStaticIP("10.230.17.212", "255.255.0.0", "10.230.0.1");
tmrBlink = new GT.Timer(500);
tmrBlink.Tick += new GT.Timer.TickEventHandler(tmrBlink_Tick);
void ethernetForMountaineerEth_NetworkUp(GTM.Module.NetworkModule sender,
GTM.Module.NetworkModule.NetworkState state)
var ledEvent = WebServer.SetupWebEvent("led");
ledEvent.WebEventReceived +=
new WebEvent.ReceivedWebEventHandler(ledEvent_WebEventReceived);
WebServer.StartLocalServer(ethernetForMountaineerEth.NetworkSettings.IPAddress, 80);
void ledEvent_WebEventReceived(string path, WebServer.HttpMethod method, Responder responder)
try
Debug.Print("Start...");
string mode = responder.GetParameterValueFromURL("mode").ToLower();
if (mode == "on")
tmrBlink.Stop();
isLedOn = true;
else if (mode == "blink")
tmrBlink.Start();
tmrBlink.Stop();
isLedOn = false;
Mainboard.SetDebugLED(isLedOn);
responder.Respond("Success");
catch(Exception ex)
Debug.Print(ex.ToString());
void tmrBlink_Tick(GT.Timer timer)
isLedOn = !isLedOn;
Hi, i have same problem, but when i try to patch responder.cs and than i put it in my project (project>add exist item) than visual studio show 20 errors.
Do you know what i did wrong?
Its my first experience with visual studio and Moutaineer ethernet mainboard.
Thank you
Klimoma
Error 1 No overload for ‘ledEvent_WebEventReceived’ matches delegate ‘Gadgeteer.Networking.WebEvent.ReceivedWebEventHandler’ C:\Users\klimoma\Documents\Visual Studio 2012\Projects\HelloMountaineer\HelloMountaineer\Program.cs 40 17 HelloMountaineer
Error 3 ‘Gadgeteer.Networking.WebEvent’ does not contain a definition for ‘ContentType’ and no extension method ‘ContentType’ accepting a first argument of type ‘Gadgeteer.Networking.WebEvent’ could be found (are you missing a using directive or an assembly reference?) C:\Users\klimoma\Documents\Visual Studio 2012\Projects\HelloMountaineer\HelloMountaineer\Responder.cs 57 26 HelloMountaineer
Error 4 ‘Gadgeteer.Networking.WebEvent’ does not contain a definition for ‘ResponseData’ and no extension method ‘ResponseData’ accepting a first argument of type ‘Gadgeteer.Networking.WebEvent’ could be found (are you missing a using directive or an assembly reference?) C:\Users\klimoma\Documents\Visual Studio 2012\Projects\HelloMountaineer\HelloMountaineer\Responder.cs 58 26 HelloMountaineer
Error 5 ‘Gadgeteer.Networking.WebEvent’ does not contain a definition for ‘ContentType’ and no extension method ‘ContentType’ accepting a first argument of type ‘Gadgeteer.Networking.WebEvent’ could be found (are you missing a using directive or an assembly reference?) C:\Users\klimoma\Documents\Visual Studio 2012\Projects\HelloMountaineer\HelloMountaineer\Responder.cs 87 26 HelloMountaineer
Error 6 ‘Gadgeteer.Networking.WebEvent’ does not contain a definition for ‘ResponseData’ and no extension method ‘ResponseData’ accepting a first argument of type ‘Gadgeteer.Networking.WebEvent’ could be found (are you missing a using directive or an assembly reference?) C:\Users\klimoma\Documents\Visual Studio 2012\Projects\HelloMountaineer\HelloMountaineer\Responder.cs 89 26 HelloMountaineer
Error 7 ‘Gadgeteer.Networking.WebEvent’ does not contain a definition for ‘ContentType’ and no extension method ‘ContentType’ accepting a first argument of type ‘Gadgeteer.Networking.WebEvent’ could be found (are you missing a using directive or an assembly reference?) C:\Users\klimoma\Documents\Visual Studio 2012\Projects\HelloMountaineer\HelloMountaineer\Responder.cs 104 26 HelloMountaineer
Error 8 ‘Gadgeteer.Networking.WebEvent’ does not contain a definition for ‘ResponseData’ and no extension method ‘ResponseData’ accepting a first argument of type ‘Gadgeteer.Networking.WebEvent’ could be found (are you missing a using directive or an assembly reference?) C:\Users\klimoma\Documents\Visual Studio 2012\Projects\HelloMountaineer\HelloMountaineer\Responder.cs 105 26 HelloMountaineer
Error 9 ‘Gadgeteer.Networking.WebEvent’ does not contain a definition for ‘ContentType’ and no extension method ‘ContentType’ accepting a first argument of type ‘Gadgeteer.Networking.WebEvent’ could be found (are you missing a using directive or an assembly reference?) C:\Users\klimoma\Documents\Visual Studio 2012\Projects\HelloMountaineer\HelloMountaineer\Responder.cs 121 26 HelloMountaineer
Error 10 ‘Gadgeteer.Networking.WebEvent’ does not contain a definition for ‘ResponseData’ and no extension method ‘ResponseData’ accepting a first argument of type ‘Gadgeteer.Networking.WebEvent’ could be found (are you missing a using directive or an assembly reference?) C:\Users\klimoma\Documents\Visual Studio 2012\Projects\HelloMountaineer\HelloMountaineer\Responder.cs 122 26 HelloMountaineer
Error 11 ‘Gadgeteer.Networking.BinaryResponseTemplate’ is inaccessible due to its protection level C:\Users\klimoma\Documents\Visual Studio 2012\Projects\HelloMountaineer\HelloMountaineer\Responder.cs 155 17 HelloMountaineer
Error 12 ‘Gadgeteer.Networking.WebEvent’ does not contain a definition for ‘ComputeResponse’ and no extension method ‘ComputeResponse’ accepting a first argument of type ‘Gadgeteer.Networking.WebEvent’ could be found (are you missing a using directive or an assembly reference?) C:\Users\klimoma\Documents\Visual Studio 2012\Projects\HelloMountaineer\HelloMountaineer\Responder.cs 155 65 HelloMountaineer
Error 13 ‘Gadgeteer.Networking.BinaryResponseTemplate’ does not contain a definition for ‘Header’ and no extension method ‘Header’ accepting a first argument of type ‘Gadgeteer.Networking.BinaryResponseTemplate’ could be found (are you missing a using directive or an assembly reference?) C:\Users\klimoma\Documents\Visual Studio 2012\Projects\HelloMountaineer\HelloMountaineer\Responder.cs 157 30 HelloMountaineer
Error 14 ‘Gadgeteer.Networking.BinaryResponseTemplate’ does not contain a definition for ‘Header’ and no extension method ‘Header’ accepting a first argument of type ‘Gadgeteer.Networking.BinaryResponseTemplate’ could be found (are you missing a using directive or an assembly reference?) C:\Users\klimoma\Documents\Visual Studio 2012\Projects\HelloMountaineer\HelloMountaineer\Responder.cs 157 57 HelloMountaineer
Error 15 ‘Gadgeteer.Networking.BinaryResponseTemplate’ does not contain a definition for ‘Header’ and no extension method ‘Header’ accepting a first argument of type ‘Gadgeteer.Networking.BinaryResponseTemplate’ could be found (are you missing a using directive or an assembly reference?) C:\Users\klimoma\Documents\Visual Studio 2012\Projects\HelloMountaineer\HelloMountaineer\Responder.cs 159 53 HelloMountaineer
Error 16 ‘Gadgeteer.Networking.BinaryResponseTemplate’ does not contain a definition for ‘Header’ and no extension method ‘Header’ accepting a first argument of type ‘Gadgeteer.Networking.BinaryResponseTemplate’ could be found (are you missing a using directive or an assembly reference?) C:\Users\klimoma\Documents\Visual Studio 2012\Projects\HelloMountaineer\HelloMountaineer\Responder.cs 159 73 HelloMountaineer
Error 17 ‘Gadgeteer.Networking.BinaryResponseTemplate’ does not contain a definition for ‘Content’ and no extension method ‘Content’ accepting a first argument of type ‘Gadgeteer.Networking.BinaryResponseTemplate’ could be found (are you missing a using directive or an assembly reference?) C:\Users\klimoma\Documents\Visual Studio 2012\Projects\HelloMountaineer\HelloMountaineer\Responder.cs 161 34 HelloMountaineer
Error 18 ‘Gadgeteer.Networking.BinaryResponseTemplate’ does not contain a definition for ‘Content’ and no extension method ‘Content’ accepting a first argument of type ‘Gadgeteer.Networking.BinaryResponseTemplate’ could be found (are you missing a using directive or an assembly reference?) C:\Users\klimoma\Documents\Visual Studio 2012\Projects\HelloMountaineer\HelloMountaineer\Responder.cs 161 62 HelloMountaineer
Error 19 ‘Gadgeteer.Networking.BinaryResponseTemplate’ does not contain a definition for ‘Content’ and no extension method ‘Content’ accepting a first argument of type ‘Gadgeteer.Networking.BinaryResponseTemplate’ could be found (are you missing a using directive or an assembly reference?) C:\Users\klimoma\Documents\Visual Studio 2012\Projects\HelloMountaineer\HelloMountaineer\Responder.cs 163 57 HelloMountaineer
Error 20 ‘Gadgeteer.Networking.BinaryResponseTemplate’ does not contain a definition for ‘Content’ and no extension method ‘Content’ accepting a first argument of type ‘Gadgeteer.Networking.BinaryResponseTemplate’ could be found (are you missing a using directive or an assembly reference?) C:\Users\klimoma\Documents\Visual Studio 2012\Projects\HelloMountaineer\HelloMountaineer\Responder.cs 163 78 HelloMountaineer
Error 21 ‘Gadgeteer.Networking.Body’ does not contain a constructor that takes 2 arguments C:\Users\klimoma\Documents\Visual Studio 2012\Projects\HelloMountaineer\HelloMountaineer\Responder.cs 246 33 HelloMountaineer
Hi klimoma,
I followed workaround from user25519:Download Gadgeteer Library from Codeplex, patch Responder.cs in the Webserver43 project (line 543) and make dll. Copy Gadgeteer.WebServer.dll, Gadgeteer.WebServer.pdb, Gadgeteer.WebServer.xml into C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.3 and include new dll into your project.
hi,
Thx i did what you said and now its works, but not correctly when i send 6-7 requests (on/off/blink) so it stop response on http request.
Did u try more requests? Is it working for you?
