This is a tangent of the issue we are talking about in Pete’s Win8 Robot thread here: http://www.tinyclr.com/forum/topic?id=8680
The issue:
Since the 8/24 RC code (and possibly the drop before that), I’m having the issue that if I use MoveMotor, MoveMotorRamp or MoveMotorNB and send it any POSITIVE value, the controller becomes mostly unresponsive to other commands. I find that in certain cases, if I send a POSITIVE after the NEGATIVE, the motor will either stop or reverse itself. If I send a ZERO after the NEGATIVE value, assuming the previous NEGATIVE value wasn’t -100, the channel maxes itself out and then becomes completely unresponsive.
Also, I haven’t had this run into it on MoveMotor, but on MoveMotorRamp and MoveMotorRampNB, if I send it a -100 or any other NEGATIVE number followed by a zero, I get an unhandled exception in GTM.GHIElectronics.MotorControllerL298.DLL.
I haven’t grabbed the source for the DLL to step into it yet, will try to do that at some point today.
The hardware:
I haven’t tried this on a Hydra or Spider yet, but this is definitely broken on my Cerberus.
Mainboard - Cerberus
DeviceInfo:
HAL build info: 4.2.0.0, Copyright Oberon microsystems, Inc.
OEM Product codes (vendor, model, SKU): 255, 0, 65535
Serial Numbers (module, system):
FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Solution Build Info: 4.2.3.0, Copyright (C) GHI Electronics, LLC
AppDomains:
default, id=1
Assemblies:
mscorlib,4.2.0.0
Microsoft.SPOT.Native,4.2.0.0
Microsoft.SPOT.Hardware,4.2.0.0
Microsoft.SPOT.Graphics,4.2.0.0
Microsoft.SPOT.TinyCore,4.2.0.0
Microsoft.SPOT.Hardware.SerialPort,4.2.0.0
Microsoft.SPOT.IO,4.2.0.0
System.IO,4.2.0.0
Microsoft.SPOT.Hardware.OneWire,4.2.0.0
Microsoft.SPOT.Hardware.Usb,4.2.0.0
Microsoft.SPOT.Hardware.PWM,4.2.0.1
Microsoft.SPOT.Net,4.2.0.0
System,4.2.0.0
Gadgeteer,2.42.0.0
Microsoft.SPOT.Net.Security,4.2.0.0
GTM.GHIElectronics.Extender,4.1.5.0
GHIElectronics.Gadgeteer.FEZCerberus,1.0.6.0
GTM.GHIElectronics.IRReceiver,1.0.0.0
System.Http,4.2.0.0
GHI.OSHW.Hardware,4.2.3.0
ServoTest,1.0.0.0
System.Net.Security,4.2.0.0
GTM.GHIElectronics.MotorControllerL298,1.0.3.0
Microsoft.SPOT.Touch,4.2.0.0
Modules:
GHI IRreceiver (socket 2)
GHI motorControllerL298 (socket 4)
GHI UsbClientDP (socket 8)
Code:
Deployment assemblies:
Create TS.
Loading start at 805b870, end 808448c
Assembly: mscorlib (4.2.0.0) Assembly: Microsoft.SPOT.Native (4.2.0.0) Assembly: Microsoft.SPOT.Hardware (4.2.0.0)
Assembly: Microsoft.SPOT.Graphics (4.2.0.0) Assembly: Microsoft.SPOT.TinyCore (4.2.0.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.2.0.0) Assembly: Microsoft.SPOT.IO (4.2.0.0)
Assembly: System.IO (4.2.0.0) Assembly: Microsoft.SPOT.Hardware.OneWire (4.2.0.0)
Assembly: Microsoft.SPOT.Hardware.Usb (4.2.0.0) Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1)
Assembly: Microsoft.SPOT.Net (4.2.0.0) Assembly: System (4.2.0.0) Loading Deployment Assemblies.
Attaching deployed file.
Assembly: Gadgeteer (2.42.0.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Net.Security (4.2.0.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.Extender (4.1.5.0) Attaching deployed file.
Assembly: GHIElectronics.Gadgeteer.FEZCerberus (1.0.6.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.IRReceiver (1.0.0.0) Attaching deployed file.
Assembly: System.Http (4.2.0.0) Attaching deployed file.
Assembly: GHI.OSHW.Hardware (4.2.3.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.UsbClientDP (1.0.0.0) Attaching deployed file.
Assembly: ServoTest (1.0.0.0) Attaching deployed file.
Assembly: System.Net.Security (4.2.0.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.MotorControllerL298 (1.0.3.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Touch (4.2.0.0) Resolving.
Motor code:
void irreceiver_IREvent(object sender, IR_Receiver.IREventArgs e)
switch (e.Button)
case 32: //forward -- CH_UP
Debug.Print("forward");
motorControllerL298.MoveMotor(MotorControllerL298.Motor.Motor1, -75);
motorControllerL298.MoveMotor(MotorControllerL298.Motor.Motor2, -75);
break;
case 33: //backward -- CH_DN
Debug.Print("backward");
motorControllerL298.MoveMotor(MotorControllerL298.Motor.Motor1, 75);
motorControllerL298.MoveMotor(MotorControllerL298.Motor.Motor2, 75);
break;
case 13: //stop -- MUTE
Debug.Print("Stop");
motorControllerL298.MoveMotor(MotorControllerL298.Motor.Motor1, 0);
motorControllerL298.MoveMotor(MotorControllerL298.Motor.Motor2, 0);
break;
case 17: //left -- VOL_LFT
position = Left;
break;
case 16: //right -- VOL_RIGHT
position = Right;
break;
case 11: //center -- AV/TV
position = Center;
break;
default:
break;
