The markings “M1” and “M2” do not correspond to motor1 and motor2, respectively.
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace MotorController
public partial class Program
timer.Tick +=<tab><tab>
timer.Start();
motorControllerL298.MoveMotor(MotorControllerL298.Motor.Motor2, 0);
// The following causes the motor connected to "M2" to turn
motorControllerL298.MoveMotor(MotorControllerL298.Motor.Motor1, 100);
Thread.Sleep(5000);
motorControllerL298.MoveMotor(MotorControllerL298.Motor.Motor1, 0);
// The following causes the motor connected to "M1" to turn
Debug.Print("Ramp up to 100");
motorControllerL298.MoveMotorRamp(MotorControllerL298.Motor.Motor2, 100, 5000);
Thread.Sleep(5000);
Debug.Print("Ramp down to 0");
motorControllerL298.MoveMotorRamp(MotorControllerL298.Motor.Motor2, 0, 5000);
Debug.Print("Ramp down to -100");
motorControllerL298.MoveMotorRamp(MotorControllerL298.Motor.Motor2, -100, 5000);
Thread.Sleep(5000);
Debug.Print("Ramp up to 0");
Debug.Print("Stop motor");
