I made some changes to the the motor shield driver:
Changed (byte) to (PWM.pin) in:
_pwm1 = new PWM((PWM.Pin)FEZ_Pin.PWM.Di5);
Because we don’t need the old .cs file dealing with pins.
Changed 100-Math.Abs(speed2) to remove the “100-”:
_pwm2.Set(1000, (byte)(Math.Abs(speed2)));
Because the previous code had 100-100 = 0 when speed2 = 100.
You should probably start a new thread with more detail on what you’re trying to accomplish, rather than replying to a 2 year old thread.
Start with what equipment you have (if any), and what you’re trying to do, and any constraints you’re working within (budget, programming language, etc.).
