My PC and the module both are connecting to a hub.
Can you plug it into a switch that has other things connected to it? It’s almost impossible to get a packet collision when its just your pc and module connected to eachother.
then the fix is easy, just use a hub :)).
yeb, we will try.
Never heard of a 48 ports hub with VLAN managament though…
Here’s the project again.
Also, don’t forget to enable USB Host. If you don’t have USB host, then the module will not crash. Just the network will stop working, but the rest of the code continues to work. If you have USB host, then the entire software stops working.
Have you been able to reproduce the issue with your project, @Dat_Tran?
With your project, we can reproduce network not response but could not reproduce crash issue, with/without usb connected.
We will try more.
That’s weird. Are you using usb host?
yes we did.
I noticed the issue was closed on GitHub.
Is there a workaround for 2.1p4 or do I wait for 2.1rc1? ![]()
RC1 is 2 days away
