I am using the Modbus gateway, Ethernet to an RTU client. The gateway works fine. External TCP/IP clients can access the RTU device as expected.
How do I access the RTU device in my TinyCLR code?
What I have below works but I get frequent Modbus timeout errors on the mbMaster.ReadHoldingRegisters() while TCP/IP devices are accessing the device, at the same time the TCP/IP device times out as well. Is there a better way to do this?
I tried mbMaster as a ModbusTcpInterface, but that didn’t work. I tried the “127.0.0.1” address and the device’s actual IP address but neither worked.
var mbInterface = new ModbusRtuInterface(
port1,
9600,
8,
UartStopBitCount.One,
UartParity.None
var gateway = new ModbusGateway(ModbusConst.TcpDeviceAddress, mbInterface, 1000);
var tcpInterfaceListener = ModbusTcpInterface.StartDeviceListener(gateway);
mbMaster = new ModbusMaster(mbInterface, mbSlaveSync);
gateway.Start();
ushort[] _data;
while(true)
try
_data = mbMaster.ReadHoldingRegisters(1, 96, 6, 2000);
catch(Exception)
Thread.Sleep(1000);
