MMP Error on build
Not sure if this question should be here or in Gadgeteer.
I move a working Raptor application from my PC over to my Surface 4 Pro. On a build I always receive an error MMP.
Image is attached showing a new Gadgeteer application. It is only the Raptor and nothing else. If I do a build I receive
the MMP error
I have looked around the NET but I have found nothing useful.
Using VS Studio 2013 Pro, Windows 10, and new installation of Framework, Core, and SDK (Insatlled in that order)
Thanks!
Anyone have a solution?
@ cyberh0me -
Thanks for the reply!
I saw that post and it did not help my issue.
However, I ‘THINK’ I may have fixed my problem. I can now build my old file moved onto my Surface 4 Pro.
Image attached- Please do not ask why I chose that NET Framework… (Just seemed like a good idea at the time)
I’ll see how it goes …
The issue is the error message is really bad. It should say you need to install .net 3.5. You can do this from the control panel, with add Windows features and then choose .net 3.5.
This is another example of how little things can make it really hard to get started.
You can instead add the config file, which makes it work without needing to install .net 3.5. This would be a good thing to fix.
