GHI hardware + Skewworks software + 3D printer = Sweeet.
Meet my new testing & diagnostics tool the MiniNuke Mark III. It started off in a $1 flimsy plastic case I bought and cut holes in (I believe the case was originally intended to store thread or some such). Then it got an acrylic case from GHI (which, yeah, I could have designed better). And now it has it’s final home in a 3D printed case.
Hydra powered with T35, Ethernet, joystick, 2 buttons, SD card and USB Serial. It’s also got a LiPo battery with charger (barrel jack & usb). I’ll be using this to test out my GUI software as well as trouble shoot various things.
And if you’re interested here’s what I learned from 3D printing the case.
I don’t care if your measurements are perfect, the print won’t be so you’d better lay in some wiggle room.
2mm is an ideal case thickness
Faceplates aren’t a great idea if you don’t bare in mind lesson 1
A gap of 1mm in your design will leave you a gap of nothing on a real print, make your buffer sizes bigger than that!
A bump of 1mm will be greater than 1mm.
Hairspray + blue painters tape is an excellent way to prevent warping.
