Is it possible to get just one pulse for 100 microseconds when i press a button in fez boards (i am using a panda 2). from other posts it looks like we cannot get microsecond outputs from netmf?? If possible how to do that? i can use timer for millisecond timings but not for microsecond
Use OutputCompare
Look for OutputCompare in library documentation: http://www.ghielectronics.com/downloads/NETMF/Library%20Documentation/Index.html
It’s in the GHIElectronics.NETMF.Hardware namespace
got it. thanks
namespace PWM_Sample_1
class PWM_UsingOC
OutputCompare _oc;
uint[] timings = new uint[2];
public PWM_UsingOC(FEZ_Pin.Digital dp)
_oc = new OutputCompare((Cpu.Pin)dp, false, timings.Length);
PWM_UsingOC pwm_5 = new PWM_UsingOC(FEZ_Pin.Digital.Di5);
PWM_UsingOC pwm_2 = new PWM_UsingOC(FEZ_Pin.Digital.Di2);
pwm_5.SetPulse(1000 * 1000 * 10, 1000);
pwm_2.SetPulse(1000 * 1000 * 20, 1000);
Thread.Sleep(-1);
public void SetPulse(uint period_nanosecond, uint highTime_nanosecond)
uint period = period_nanosecond / 1000;
uint highTime = highTime_nanosecond / 1000;
timings[0] = highTime;
timings[1] = period - highTime;
_oc.Set(true, timings, 0, 2, true);
public void Set(int frequency, byte dutyCycle)
// in nano seconds
uint period = 0;
uint highTime = 0;
period = (uint)(1000000000 / frequency);
highTime = (uint)((ulong)(period) * dutyCycle / 100);
SetPulse(period, highTime);
Thanks for sharing. Please use code tags so it is easier to read code please.
