Our announcement today is about a whole new coding option, MicroPython on SITCore, specifically the new SC13xxx family of products.
You ask why? We say why not! Python is a powerful scripting language that requires no installation. You can type your code in the first minute using notepad or just enter the code through REPL.
These two FEZ (Fast & Easy) boards, the FEZ Pico and FEZ Flea, both support MicroPython. Powered by the small but powerful, SITCore SC13048Q. The FEZ Pico is inspired by the RPI Pico’s form factor, while the FEZ Flea draws its inspiration from the Seeeduino Xiao. Both capitalize off the respective ecosystems. And, of course, both support TinyCLR OS.
MicroPython is very interesting and has some real cool thing we are learning about slowly. The mix of built in file system and REPL is very cool Debugging
I have just tried it and it it works! Just select MicroPython Generic from run->interperter and then select the Virtual Serial port from you SITCore device.
Gus you are amazing! “I had a dream”: Python on GHI products with Thonny to program them and two hours later it is real and documented. We will be able to work in Python or C# on the same products. I feel like my summer vacation is going to be busy.
