Hello … I just received my FEZ Spider starter kit this week.
I have downloaded and installed the .NET Micro Framework, v4.2, and the latest GHI drivers, etc. I am running 32-bit Windows 7 Pro (all latest patches, etc applied) and VS 2010 Pro.
After the GHI drivers were installed, I updated the firmware on the Spider. At first it didn’t work but after some research on this site, I learned to manually update the device driver. Everything looked great. It is now booting up with Version 4.2.5.0 showing on the attached display.
I set the dip switches back to default and reset the board. I hear the usual tones and see “GHI NETMF Debug Interface” under the USB controllers in the device manager.
However, when I go to deploy anything to the device, VS gives me a “device not found or cannot be opened - USB:Gadgeteer” error. So, I tried to see if MFDeploy can see the device. I set MFDeploy to USB (from serial) and nothing …
After more research on this site, I back out all software expect VS 2010 and reloaded (twice!!). Micro Framework installed first followed by GHI drivers, etc. I updated the firmware on the spider again … no problems. I still see nothing on MFDeploy.
I tried the same process on my MAC, booted to windows 7 pro 64 bit, but I had the same problems.
I really don’t want to send this board back … it looks like it is working but there is something I’m missing in windows or a driver or something.
hey dgies68, welcome to the forum !
sounds to me like the drivers didn’t load - the fact that the firmware shows 4.2.5.0 is a GREAT sign. So show us the device manager screenshot to see the driver - and follow the manual install of the driver, in bold, at http://www.tinyclr.com/forum/topic?id=9388
@ Petabyte, if you downloaded the 4.2 RTM not 4.2 QFE2 update, then you need to at least uninstall the GHI SDKs and then netmf sdk, then reinstall as per http://www.ghielectronics.com/support/dotnet-micro-framework and then make sure you apply the firmware again
Dear Brett, I was following the exact page that you provided (.NET Micro Framework)
Sorry, but I got confused now, the link in that page, which is for (Microsoft .NET Micro Framework 4.2 QFE2 SDK) is directing me to this page: https://netmf.codeplex.com/releases/view/91594
Then I found and downloaded the RECOMMENDED DOWNLOAD, which was “SDK 4.2 (RTM QFE2)”
So it seems that RTM & QEF2 is the same thing in one file, isn’t it?
and do you think this framework has anything to do for pinging the board??
because I think it is needed only for VS 2010 …
hi,
I have a problem with my new FezSpider, when I plug it on my Win XP PC recognize “GHI BootLoader Interface(COM10)” without error, but when i try update firmware with “FEZSPider Firmware Updater” return “No Responce from device”; so i tried connect with Hyperterm and download TinyBooter File, but when i try to RUN Firmware return “Bad Firmware”. I tried all way… reinstal usb driver, use a Win/7 Pc… nothing… dont work! can someone help me? Thank you.
