First off this is my very first Arduino project and i am pretty much struggling to get it to work.
This code was downloaded from their site and is for an UNO board (which i believe Medusa mini is hardware equivalent?)
so in the Arduino ide i select Medusa board
I change the irq to 7 as i am connected to pin 3 of socket 1
I change the vben to 9 as i am connected to pin 5 of socket 1
I change the cs to 10 as i am connected to pin 6 of socket 1
are those the right pin assignments or do i go off the processor ie for socket 1 pin 3 ic IO7 which is 11 / PD7?
it compiles and uploads ok but it is giving me this response
[quote]Hello, CC3000!
RX Buffer : 131 bytes
TX Buffer : 131 bytes
Initialising the CC3000 …
IRQ pin is not an INT pin!
Unable to initialise the CC3000! Check your wiring?
[/quote]
so am i totally way off in porting this code over to Medusa?
This is an example for the Adafruit CC3000 Wifi Breakout & Shield
Designed specifically to work with the Adafruit WiFi products:
----> https://www.adafruit.com/products/1469
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried, Kevin Townsend and Phil Burgess for
Adafruit Industries. BSD license, all text above must be included
in any redistribution
This example queries an NTP time server to get the current "UNIX time"
(seconds since 1/1/1970, UTC (GMT)), then uses the Arduino's internal
timer to keep relative time. The clock is re-synchronized roughly
once per day. This minimizes NTP server misuse/abuse.
The RTClib library (a separate download, and not used here) contains
functions to convert UNIX time to other formats if needed.
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#include <SPI.h>
// These are the interrupt and control pins
#define ADAFRUIT_CC3000_IRQ 7 // MUST be an interrupt pin!
// These can be any two pins
#define ADAFRUIT_CC3000_VBAT 9
#define ADAFRUIT_CC3000_CS 10
// Use hardware SPI for the remaining pins
// On an UNO, SCK = 13, MISO = 12, and MOSI = 11
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT,
SPI_CLOCK_DIV2); // you can change this clock speed but DI
#define WLAN_SSID "myNetwork" // cannot be longer than 32 characters!
#define WLAN_PASS "myPassword"
// Security can be WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
#define WLAN_SECURITY WLAN_SEC_WEP
Adafruit_CC3000_Client client;
const unsigned long
connectTimeout = 15L * 1000L, // Max time to wait for server connection
responseTimeout = 15L * 1000L; // Max time to wait for data from server
int
countdown = 0; // loop() iterations until next time server query
unsigned long
lastPolledTime = 0L, // Last value retrieved from time server
sketchTime = 0L; // CPU milliseconds since last server query
void setup(void)
Serial.begin(115200);
Serial.println(F("Hello, CC3000!\n"));
displayDriverMode();
Serial.println(F("\nInitialising the CC3000 ..."));
if (!cc3000.begin()) {
Serial.println(F("Unable to initialise the CC3000! Check your wiring?"));
for(;;);
uint16_t firmware = checkFirmwareVersion();
if ((firmware != 0x113) && (firmware != 0x118)) {
Serial.println(F("Wrong firmware version!"));
for(;;);
displayMACAddress();
Serial.println(F("\nDeleting old connection profiles"));
if (!cc3000.deleteProfiles()) {
Serial.println(F("Failed!"));
while(1);
/* Attempt to connect to an access point */
char *ssid = WLAN_SSID; /* Max 32 chars */
Serial.print(F("\nAttempting to connect to ")); Serial.println(ssid);
/* NOTE: Secure connections are not available in 'Tiny' mode! */
if (!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) {
while(1);
Serial.println(F("Connected!"));
/* Wait for DHCP to complete */
Serial.println(F("Request DHCP"));
while (!cc3000.checkDHCP()) {
delay(100); // ToDo: Insert a DHCP timeout!
/* Display the IP address DNS, Gateway, etc. */
while (!displayConnectionDetails()) {
delay(1000);
// To reduce load on NTP servers, time is polled once per roughly 24 hour period.
// Otherwise use millis() to estimate time since last query. Plenty accurate.
void loop(void) {
if(countdown == 0) { // Time's up?
unsigned long t = getTime(); // Query time server
if(t) { // Success?
lastPolledTime = t; // Save time
sketchTime = millis(); // Save sketch time of last valid time query
countdown = 24*60*4-1; // Reset counter: 24 hours * 15-second intervals
} else {
countdown--; // Don't poll; use math to figure current time
unsigned long currentTime = lastPolledTime + (millis() - sketchTime) / 1000;
Serial.print(F("Current UNIX time: "));
Serial.print(currentTime);
Serial.println(F(" (seconds since 1/1/1970 UTC)"));
delay(15000L); // Pause 15 seconds
@ brief Displays the driver mode (tiny of normal), and the buffer
size if tiny mode is not being used
@ note The buffer size and driver mode are defined in cc3000_common.h
void displayDriverMode(void)
#ifdef CC3000_TINY_DRIVER
Serial.println(F("CC3000 is configure in 'Tiny' mode"));
#else
Serial.print(F("RX Buffer : "));
Serial.print(CC3000_RX_BUFFER_SIZE);
Serial.println(F(" bytes"));
Serial.print(F("TX Buffer : "));
Serial.print(CC3000_TX_BUFFER_SIZE);
#endif
@ brief Tries to read the CC3000's internal firmware patch ID
uint16_t checkFirmwareVersion(void)
uint8_t major, minor;
uint16_t version;
#ifndef CC3000_TINY_DRIVER
if(!cc3000.getFirmwareVersion(&major, &minor))
Serial.println(F("Unable to retrieve the firmware version!\r\n"));
version = 0;
Serial.print(F("Firmware V. : "));
Serial.print(major); Serial.print(F(".")); Serial.println(minor);
version = major; version <<= 8; version |= minor;
#endif
return version;
@ brief Tries to read the 6-byte MAC address of the CC3000 module
void displayMACAddress(void)
uint8_t macAddress[6];
if(!cc3000.getMacAddress(macAddress))
Serial.println(F("Unable to retrieve MAC Address!\r\n"));
Serial.print(F("MAC Address : "));
cc3000.printHex((byte*)&macAddress, 6);
@ brief Tries to read the IP address and other connection details
bool displayConnectionDetails(void)
uint32_t ipAddress, netmask, gateway, dhcpserv, dnsserv;
if(!cc3000.getIPAddress(&ipAddress, &netmask, &gateway, &dhcpserv, &dnsserv))
Serial.println(F("Unable to retrieve the IP Address!\r\n"));
return false;
Serial.print(F("\nIP Addr: ")); cc3000.printIPdotsRev(ipAddress);
Serial.print(F("\nNetmask: ")); cc3000.printIPdotsRev(netmask);
Serial.print(F("\nGateway: ")); cc3000.printIPdotsRev(gateway);
Serial.print(F("\nDHCPsrv: ")); cc3000.printIPdotsRev(dhcpserv);
Serial.print(F("\nDNSserv: ")); cc3000.printIPdotsRev(dnsserv);
Serial.println();
return true;
// Minimalist time server query; adapted from Adafruit Gutenbird sketch,
// which in turn has roots in Arduino UdpNTPClient tutorial.
unsigned long getTime(void) {
uint8_t buf[48];
unsigned long ip, startTime, t = 0L;
Serial.print(F("Locating time server..."));
// Hostname to IP lookup; use NTP pool (rotates through servers)
if(cc3000.getHostByName("pool.ntp.org", &ip)) {
static const char PROGMEM
timeReqA[] = { 227, 0, 6, 236 },
timeReqB[] = { 49, 78, 49, 52 };
Serial.println(F("\r\nAttempting connection..."));
startTime = millis();
do {
client = cc3000.connectUDP(ip, 123);
} while((!client.connected()) &&
((millis() - startTime) < connectTimeout));
if(client.connected()) {
Serial.print(F("connected!\r\nIssuing request..."));
// Assemble and issue request packet
memset(buf, 0, sizeof(buf));
memcpy_P( buf , timeReqA, sizeof(timeReqA));
memcpy_P(&buf[12], timeReqB, sizeof(timeReqB));
client.write(buf, sizeof(buf));
Serial.print(F("\r\nAwaiting response..."));
while((!client.available()) &&
((millis() - startTime) < responseTimeout));
if(client.available()) {
client.read(buf, sizeof(buf));
t = (((unsigned long)buf[40] << 24) |
((unsigned long)buf[41] << 16) |
((unsigned long)buf[42] << 8) |
(unsigned long)buf[43]) - 2208988800UL;
Serial.print(F("OK\r\n"));
client.close();
if(!t) Serial.println(F("error"));
return t;
