Unfortunately local file system is not implemented on mBuino. You will need an external storage device for that (SPI SDcard, Serial EEPROM, etc.)
#define DEVICE_LOCALFILESYSTEM 0
/* mbed Microcontroller Library
* Copyright (c) 2006-2013 ARM Limited
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
#ifndef MBED_DEVICE_H
#define MBED_DEVICE_H
#define DEVICE_PORTIN 1
#define DEVICE_PORTOUT 1
#define DEVICE_PORTINOUT 1
#define DEVICE_INTERRUPTIN 1
#define DEVICE_ANALOGIN 1
#define DEVICE_ANALOGOUT 0
#define DEVICE_SERIAL 1
#define DEVICE_I2C 1
#define DEVICE_I2CSLAVE 1
#define DEVICE_SPI 1
#define DEVICE_SPISLAVE 1
#define DEVICE_CAN 0
#define DEVICE_RTC 0
#define DEVICE_ETHERNET 0
#define DEVICE_PWMOUT 1
#define DEVICE_SEMIHOST 0
#define DEVICE_ID_LENGTH 32
#define DEVICE_MAC_OFFSET 20
#define DEVICE_SLEEP 1
#define DEVICE_DEBUG_AWARENESS 0
#define DEVICE_STDIO_MESSAGES 1
#define DEVICE_ERROR_PATTERN 1
#include "objects.h"
#endif
FSR’s require a hard sharp object to make a reliable measurement. If you sandwiched it in some sort of enclosure then it might work but I agree with Architect that it would be really hard to filter out the noise. Perhaps a flex sensor or gyro in your pocket to tell when you are bending at the waist?
Or if your phone has NFC, you put an NFC tag on every seat (cheaper than RFID by far) that you usually use, and have the phone log the sitting via BT/BTLE, or other wireless protocol.
