10.9.4 Mavericks
Power from usb is delivered. LEDs flashing. Awesome.
Can’t see the device at all from the mac
not showung up as usb device
ls /dev/* does not show it
ls /Volumes/ does not show it up as well
Suggestions? I’m a all mac person. Don’t have easy access to PC / Windows.
@ DaddyOh - I played a bit on my Linux box, and didn’t have many problems. I used Can the 11U35 actually be programmed using mbed? - Question | Mbed
as a guide. Their are comments about Mac’s there as well. Note, however, I did not have to resort to dd, drag and drop worked for me. But, if you have problems with drag and drop, dd is definitely to avoid any problems that the software stack used by cp (and other high-level filesystem I/O commands).
I had to use sudo because all the files here are owned by root
#then make it a exceutable shell script
sudo chmod +x /usr/local/bin/savemb.sh
I plug the mbunio into the usb port
hold the mb reset button down 2 seconds
(when you do this the mbuino shows up as /Volumes/CRP\ DISABLED)
I compile and save the firmware file to ~/mbuinodl
I then go to a terminal window and run ./savemb.sh
The unplug the mb and plug it back until the usb and the program runs
This is fantastic. Thanks so much for the hints. I use mac like 99+% of the time and write arduino and LPC1768 code on the mac. This means I can write mbuino code on the mac.
