I asked to module distributor, they said me it is possible as 10 mA >= 5mA.
My next question now is, can I use the 7 GPIO pins of a X socket to directly drive the Relais module…? Are outputs > 5mA ? I cannot find this information from GHI documentation…
5mA is pretty low requirement, so I am comfortable saying you’ll be fine. The place to check is the processor datasheet - there you will see that current sink/source is rated at 25mA
Thank you Brett !!! So I can skip to buy the Max0, as I need to drive 7 relais only ( I will use a breakout module to directly sold some gpio pins of my Cerberus to the arduino relais module).
