How many lines of C# code fit inside the memory of a FEZDomino approximately? The RAM is used for both the programs and the variables, right? So the larger the program the smaller the amount of memory you can use? Or is there a set minimum set aside for variables?
Thousands of lines of code. What exactly do you need?
@ BigPilot
Please have a look at these three threads:
http://www.tinyclr.com/forum/2/5282/
http://www.tinyclr.com/forum/2/4743/
http://www.tinyclr.com/forum/2/4627
