I would like to know if I can setup an UART port at 2.000.000 bauds ? If so what should be the fractional divider register ?
It’s to connect the spider to a 32x16 RVB led display.
I remember last time i tested, it gave me a wrong value if baud rate is 921600, so I think we can not reach 2.000.000 with Spider in NETMF.
If you are transmitting then you will be okay but revieve will not keep up.
@ Dat,
I make it work at 1M on a Spider for my Dynamixel AX-12 project. Using :
Register U0FDR = new Register(0xE000C028);
U0FDR.Write((8 << 4) | 1); //fix the fractional divider register
@ Gus,
Thanks for the answer. The good news it’s for my 32x16 led display I just need to transmit
PS : I have finished my AX12 “smart car”, remotely control on an Android Phone via Bluetooth. Do you think if people will be interested by an AX12 module ?
AX12 is a sweet servo
I would - any idea of how much you would charge and time to produce? Ideally, would like ability to control 2-4 AX12 or AX18s per module.
@ Gus,
After testting :
Spider : not working above 1M Baud even on transmit only
Cerberus and Hydra : are working good at 2M Baud, at least on transmit only.
@ stevepresley
I didn’t yet make accurate cost evaluation, but will say between USD 15-20.
Have you put a scope to see what you get out at 2M Baud? Just curious
Scope wil be my next Xmas gift …
PS : The Arduino Mega working well at 2MB …
@ zakhounet - what would the AX12 module do?
@ Justin, @ stevepresley
I have in mind to build a module with on one side the 10 pins Gadgeteer socket and on the other side 2 AX12 3 pins connectors + 1 Vcc connectors 2 pins (12 volts Robotis battery) . So far I am using a prototype based on a DuinoProto and the Driver is almost finished.
I’ve attached 1 picture of the BT remote via a Galaxy SIII and 1 picture of the DuinoProto and ashort demo of the “smart car”, sorry for the quality, just to show you progress done since :
http://www.tinyclr.com/forum/topic?id=8035
Cool bot!
@ Ianlee,
Thanks.
@ Justin, @ stevepresley,
This is what I have in mind but for gadgeteer :
http://www.dfrobot.com/index.php?route=product/product&product_id=579#.UJecS2c3JLs
@ zakhounet - Nice one - cool project by the way
Was think about going something similar for these… http://robosavvy.com/store/product_info.php/cPath/26_2013/products_id/1807
@ Justin,
Yes, we already talked about it, but unfortunately I don’t have such servo to test …
@ zakhounet - I feel a joint project coming on…
@ Justin,
With a great pleasure …
Shoot me an email to steve at steve presley dot net - want to discuss funding a run of these in the very near future if you’re interested.
@ steve
will do very soon.
@ stevepresley -
Done
