Well, some people just dont know when to give up!
The key is to open MAT3.0 on P0.10. Then use the External Match Register to set this pin logical high or low on match/interrupt. P0.10 is mapped to Di8 on the Mini, so I was able to create an Interruptible pin and an event handler for Di8.
You were right about using the right tool for the job, and FEZ continues to be that tool for me!
Heres my test code
* This code demonstrate how to use timer3 on the FEZ Mini to create an externally
* triggered high speed counter with interrupt and event handling.
* See: http://www.keil.com/dd/docs/datashts/philips/lpc23xx_um.pdf
* See: http://www.ghielectronics.com/downloads/FEZ/Mini/FEZMini_sch.pdf
using GHIElectronics.NETMF.Hardware.LowLevel;
namespace FEZ_Mini_Counter
private static Register T3CR; //Timer Control Register
private static Register T3IR; //Interrupt Register
static void IntButton_OnInterrupt(uint port, uint state, DateTime time)
//reset
T3CR.SetBits((1 << 1));
T3CR.ClearBits((1 << 1));
T3IR.Write(1 << 0);
static void IntDI8_OnInterrupt(uint port, uint state, DateTime time)
//The external match register caused an interrupt
Debug.Print("INTDI8 Interrupted");
//Disable the garbage collector messages
//used to generate our external timer input, could be an encoder.
PWM pwm = new PWM((PWM.Pin)FEZ_Pin.PWM.Di3);
pwm.Set(false);
pwm.Set(2, 50);
//The LDR button is used as a physical counter and interupt reset
InterruptPort IntButton = new InterruptPort((Cpu.Pin)FEZ_Pin.Interrupt.LDR, true,
Port.ResistorMode.PullUp,
Port.InterruptMode.InterruptEdgeBoth);
IntButton.OnInterrupt += new NativeEventHandler(IntButton_OnInterrupt);
//DI8 is used as the MAT3.0 pin, interrupted by the External Match Register
InterruptPort IntDI8 = new InterruptPort((Cpu.Pin)FEZ_Pin.Interrupt.Di8, true,
IntDI8.OnInterrupt += new NativeEventHandler(IntDI8_OnInterrupt);
/*PINSEL0 - 0xE002 C000
* 21:20 P0.10 GPIO Port 0.10 TXD2 SDA2 MAT3.0 00
* see page 157, LPC23XX User manual Rev. 02 — 11 February 2009
* Use the Pin function select register PINSEL0, to enable MAT3.0
* on P0.10. This is used for the External Match Register
Register PINSEL0 = new Register(0xE002C000);
PINSEL0.Write(3 << 20);
/*Power Control for Peripherals register (PCONP - 0xE01F C0C4)
* 23 PCTIM3 Timer 3 power/clock control bit.
* see pages 68-69, LPC23XX User manual Rev. 02 — 11 February 2009
* In the Power Control for Peripherals register, turn on bit 23
* to turn power on for timer3
Register PCONP = new Register(0xE01FC0C4);
PCONP.SetBits(1 << 23);
/*Pin Function Select Register 1 (PINSEL1 - 0xE002 C004)
* 15:14 P0.23 GPIO Port 0.23 AD0.0 I2SRX_CLK CAP3.0 00
* see page 158, LPC23XX User manual Rev. 02 — 11 February 2009
* Use the Pin finction select register PINSEL1, to enable Cap3.0
* on P0.23. Select An0 on Mini (Cap3.0) - An0 - Mapped to the Cap3.0
* This will be the external input for the timer, used with the Capture Control Register
Register PINSEL1 = new Register(0xE002C004);
PINSEL1.SetBits((3 << 14));//set bits 14 and 15
/*Timer Control Register (T[0/1/2/3]CR - 0xE000 4004, 0xE000 8004,0xE007 0004, 0xE007 4004)
* 0 Counter Enable When one, the Timer Counter and Prescale Counter are enabled for counting.
* When zero, the counters are disabled
* see pages 554-555, LPC23XX User manual Rev. 02 — 11 February 2009
* This will enable timer3
T3CR = new Register(0xE0074004);
T3CR.Write(1);
/*TPrescale register (T0PR - T3PR, 0xE000 400C, 0xE000 800C, 0xE007 000C, 0xE007 400C)
* The 32-bit Prescale register specifies the maximum value for the Prescale Counter.
* see page 556, LPC23XX User manual Rev. 02 — 11 February 2009
* This will set the prescale to 0 for timer3
Register T3PR = new Register(0xE007400C);
T3PR.Write(0);
/*Count Control Register (T[0/1/2/3]CTCR - 0xE000 4070, 0xE000 8070, 0xE007 0070, 0xE007 4070)
* 10 Counter Mode: TC is incremented on falling edges on the CAP input selected by bits 3:2.
* see page 555, LPC23XX User manual Rev. 02 — 11 February 2009
* This will count on falling edge of CAP3.0, An0(mini)
Register T3CTCR = new Register(0xE0074070);
T3CTCR.Write(2 << 0 | 0 << 2);
/*Capture Control Register (T[0/1/2/3]CCR - 0xE000 4028, 0xE000 8028, 0xE007 0028, 0xE007 4028)
* see page 558, LPC23XX User manual Rev. 02 — 11 February 2009
* This is set to 0, for a counter
Register T3CCR = new Register(0xE0074028);
T3CCR.ClearBits(0x07);
// To reset the counter
/*Match Control Register (T[0/1/2/3]MCR - 0xE000 4014, 0xE000 8014, 0xE007 0014, 0xE007 4014)
* 0 MR0I 1 Interrupt on MR0: an interrupt is generated when MR0 matches the value in the TC
* see page 557, LPC23XX User manual Rev. 02 — 11 February 2009
* This will generate a interrupt when MR0 and TC match
Register T3MCR = new Register(0xE0074014);
T3MCR.Write(1 << 0);
/*MR0 Match Register
* see page 553, LPC23XX User manual Rev. 02 — 11 February 2009
* This is value that will be tested against the TC
Register T3MR0 = new Register(0xE0074018);
T3MR0.Write(10); // change this value as needed
/*Interrupt Register (T[0/1/2/3]IR - 0xE000 4000, 0xE000 8000, 0xE007 0000, 0xE007 4000)
* MR0 Interrupt Interrupt flag for match channel 0.
* see page 554, LPC23XX User manual Rev. 02 — 11 February 2009
* This provides the interrupt on MR0
T3IR = new Register(0xE0074000);
T3IR.Write(1 << 0);
/*External Match Register (T[0/1/2/3]EMR - 0xE000 403C, 0xE000 803C, 0xE007 003C, 0xE007 403C)
* see page 559, LPC23XX User manual Rev. 02 — 11 February 2009
* Handel the interrupt on EM0 (MAT3.0)
* Setting bits 5:4 high, toggles the corresponding External Match bit/output (MAT3.0).
Register EM0 = new Register(0xE007403C);
EM0.Write(3 << 4);
/*Timer Counter registers (T0TC - T3TC, 0xE000 4008, 0xE000 8008, 0xE007 0008, 0xE007 4008)
* This is the count of Timer3
Register T3TC = new Register(0xE0074008);
Debug.Print("Total count: " + T3TC.Read());
Debug.Print("IR: " + T3IR.Read());
Debug.Print("External Match Register: " + EM0.Read().ToString());
Thread.Sleep(10);
}//end of while loop
}//end of Main()
}//end of class
}//end of namespace
