Massive CAN.Error.BusOff Events and no Acknowledgments from FEZ Cobra
Hi!
I’m new to the .Net Micro Framework world and EMX&FEZ Cobra.
One of my first challenges is to communicate with a car simulator over CAN.
I copied the example from the documentation which ships with the 1.0.13 SDK and I’m getting CAN messages (-> that was fast).
But I have two problems:
[ulist]
After getting 3~5 DataReceivedEvents I get a ErrorReceivedEvent with CAN.Error.BusOff which resets the CAN Bus, after that 3~5 DataReceivedEvents -> ErrorReceivedEvent -> and so on…
It seems the messages aren’t acknowledged, the simulator gets a buffer overflow (if i connect another device, which we use infield, the buffer overflow disappears).
[/ulist]
Please help.
Thank you.
Robert
Check your bit timing. CAN bus bit timing can be very very tricky.
