Say you want to use a Spider and RS21 without the Gadgeteer framework. What is the easiest way to map, say socket 6 to the correct SPI, CS and INT pins? I did it by reading the schematic (and still not sure I got it right), but is there a simple table or source code somewhere to help us go from Gadgeteer initialization to unwrapped driver initialization?
In my case I am using the RS21 and want to go from this:
to this: (may not be correct) :
```cs] _wifi = new WiFiRS9110(SPI.SPI_module.SPI3, (Cpu.Pin)10, (Cpu.Pin)18);[/code
