In docmentation about the FEZ SPider mainboard the configurable Led on the mainboard is mentioned. he led also exists, but i cannot find a way to use it other than PulseDebugLed()
I found reference to the mainboard class where SetDebugLed(True) should set the led ON , but i cant get that to work.
When i use the PulseDebugLed() , it switches the led on, but it doesnt switch offf untill the program ends…
It does however, write a “PulseDebug event” to the debug Output everytime i call the pulse command.
Does anybody know how to switch the led on or off…?
regards
Bert
Could you try this code, and place a break point on the first line, and step through the code and tell me if the light comes on?
timer.Tick +=<tab><tab>
timer.Start();
Mainboard.SetDebugLED(true); //Place a breakpoint here
Thread.Sleep(5000);
Mainboard.SetDebugLED(false);
Thank you Steven,
I did not put Mainboard before the statement.
it works now.
Great to hear. I’m glad you got it working.
Welcome to the forum!
