Magic Weel
I have a Dagu Magician Chassis with a DFRobot 1A Motor Shield For Arduino in a Cerbuino Bee and everytime I start the robot, the left weel is steering.
		const Cpu.Pin LeftMotorDirectionPin = FEZCerbuino.Pin.Digital.D7;
		const Cpu.PWMChannel LeftMotorPWMPin = FEZCerbuino.Pin.PWM.D6;
		PWM leftMotorPower;
		OutputPort leftMotorDir;
			leftMotorPower = new PWM(LeftMotorPWMPin, 1000, 0, false);
			leftMotorDir = new OutputPort(LeftMotorDirectionPin, false);
			leftMotorPower.Start();
			rightMotorPower.Start();
After I instanciate the code above, the weel stops.
Even when I deploy an empty solution with only a debug.
How can I stop this from happening?
connect it to a different pin, or use a pull-down resistor (you may have to do this if you were to move pin too).
Sorry, the default tri-state of that pin is obviously enough to enable it on the motor driver, you need to override that with a pulldown.
