Hi everybody.
We just tried to build FEZ-Cerb40 firmware with following environment:
- PK 4.2 RTM QFE1
- Keil MDK 4.20
but we get follwing 2 errors:
"c:\MicroFrameworkPK_v4_2\DeviceCode\pal\lwip\lwip_1_3_2\src\api\tcpip.c", line 548: Error: #20: identifier "UINT_MAX" is undefined
if (netifapimsg->msg.sem == SYS_SEM_NULL) {
and
"c:\MicroFrameworkPK_v4_2\DeviceCode\pal\lwip\lwip_1_3_2\src\api\api_lib.c", line 82: Error: #20: identifier "UINT_MAX" is undefined
LWIP_ASSERT("conn has no op_completed", conn->op_completed != SYS_SEM_NULL);
The undefined identifier SYS_SEM_NULL is actually defined in:
C:\MicroFrameworkPK_v4_2\DeviceCode\pal\lwip\lwip_1_3_2\contrib\ports\arm\include\arch\sys_arch.h
as follows:
#define SYS_SEM_NULL ((sys_sem_t)UINT_MAX)
which refers to UINT_MAX defined in included limits.h compiler standard include (in C:\Keil420\ARM\RV31\INC\limits.h) as follows:
#define UINT_MAX 0xffffffffU
/* maximum value for an object of type unsigned int */
So why according to you it seems that limits.h isn’t actually included?
Thanks!
