LoRa on FEZ Beta
Hi all,
Ported my RFM9X/SX127X library to TinyCLR-OS on a FEZT18-N. I’m currently testing with Dragino & Elecrow LoRa Shields.
Once I figure out why the DNS lookup on my FEZT18-W is going pop I’ll write a PoC telemetry field gateway for Adafruit.IO or Azure IoT Hubs/Central.
@KiwiBryn
This is great. Keep focus on Lora and leave azure for TinyCLR 2.0. we have a good story there to share soon
Hi Gus,
I have SX1231/RFM69 (used a lot in home automation with bonus baked in AES based crypto) and nRF24L01P library ports in pipeline as well. I’m a contractor and work is drying up as companies cut costs and enforce work from home so I may have some time for hobby projects.
@KiwiBryn
blog.devmobile.co.nz
To connect to azure, don’t you need WiFi? My understanding is that LoRa is the low power local mesh and then a gateway somewhere allows for TCP/IP?
HI Gus,
I tend to use LoRa for the “spokes” of “hub and spoke” low power IoT networks.
My library would need a wrapper which implemented a mesh networking protocol.
I was thinking about adapting my Netduino WIfi Azure IoT Hub https client code so that a FEZT18-W can act as a field gateway for other LoRa devices.
If people wanted todo LoRaWAN there are products which implement the RF HW & wireless stack in firmware from companies like MicroChip. These are often a better way to go as the vendor has usually taken care of the necessary government and network certifications.
@KiwiBryn
Once I start playing with LoRa I am going to need a private lesson from you :slight_smile:
Hi Gus,
Sounds like you need a hand with a shopping list of kit for a lab :slight_smile:
We could run some show n tell sessions if there was interest.
@KiwiBryn
pity you’re in SI (I believe, anyway) otherwise you could catch up with @Justin and share LoRa stories (he has a few modules under his belt)
Yes absolutely. I would love to see Lora as a standard built in feature in TinyCLR.
Just ordered a Lora click module and a gateway to play with…
Hi
If you have ordered are mikroBUS - MIKROE they are LoRaWAN devices.
My Library is for doing LoRa with Semtech SX127X chips
I have end-to-end LoRa samples in my blog & hackster
@KiwiBryn
Yup, the LoRa 5 Click. So your library wont work with LoRaWAN?
John
Hi
I had a quick look at the LoRa 5 chipset vendor datasheet (https://www.mipot.com/en/rf-wireless-products/lorawan-915mhz-trx-32001409/) it implements a LoRaWAN client and uses a UART connection.
My library works with SX127X based (https://www.semtech.com/products/wireless-rf/lora-transceivers/sx1276) shields + breakouts it implements a LoRa client and uses an SPI connection.
For a FEZ * duino style platforms I would look at a shield from dragino/elecrow or similar
If your using another form factor maybe a breakout with some jumper leads for testing
I have some field gateways which run on RPI (Not the latest ones as Windows 10 core) I have used these pHats. Just make sure you select a frequency band which is suitable for your location etc.
Vendors often use the terms LoRa & LoRaWAN interchangeably which can be problematic.
You can use the LMIC (GitHub - matthijskooijman/arduino-lmic: This library is deprecated, see the README for alternatives.) stack or similar on Arduino but then there are channel allocation and network compliance considerations
@KiwiBryn
Hi
@Justin and I chat every so often.
My library has been tested on his Nexus (Nexus LoRa Radio 915 MHz Payload Addressing client | devMobile's blog) & IoT Net (IoT.Net LoRa Radio 915 MHz Payload Addressing client | devMobile's blog) devices.
@KiwiBryn
