It appears that string.format is not exists on .NETMF, what can I do instead?
What is it that you are trying to accomplish?
If your just looking to concatenate some strings and string representation of numbers you can do that without String.Format.
String.Format provides a familiar printf type syntax but both methods accomplish the same thing. My guess is that the extension you linked to just does concatenation as shown above.
For more than 2 strings you can use String.Concat() instead of + Operator to boost performance
Looks like I’m a little late in the game but I also missed string.format function so I created extension method.
public static string Format(this string format, params object[] args)
if (args == null || args.Length == 0)
return format;
StringBuilder sb = new StringBuilder(format);
for (int i = 0; i < args.Length; i++)
sb.Replace("{" + i + "}", args[i].ToString());
return sb.ToString();
