Hi
I need longer (x3) gadgeteer cables… Is there somewhere I can order them, without extending them myself? I don’t want to use the Extender Module…
Hi
The cable pack we sell has different sizes. Please check the catalog.
Direct link for what Gus was talking about http://www.ghielectronics.com/catalog/product/310. There is one 50cm long cable one and 3x 20cm long ones.
I know you said you dont want to extend cables, but what about making your own?jdal did and you can see what you would need here http://www.tinyclr.com/forum/topic?id=7265
Look up the samtec samples thread. If you request a sample, they will send you some. Remember though that they talk about their cables in how many pins wide they are, so you want the ones with 5 in their name. They have at least 14-inch cables (ask me how i know ) Edit: they will send you a PAIR of cables in each length you request; unsure how many they see are reasonable number of lengths to request at once though.
Regarding longer cables, has anyone seen a need for shielded cables or a clamp-on ferrite in their high bandwidth applications?
Ferrites are easy to add but you have to pick the right material based on frequency of interest.
Shielding often works best by grounding (reference to lowest impedance) at only one end. If there is a need, I can dig up some simple illustrations showing various shield grounding schemes. The best examples IMHO are from Henry Ott’s book.
I’ve done quite a bit of testing around cable length, bandwidth, and error rate–using both differential signals and standard 3V3 logic.
Here’s my short-list of best practice recommendations so far:
A potential product idea is a “Gadgeteer Cable Extender” module which would receive an IDC cable as input and would provide an amplified differential twisted-pair output. Used in pairs, that would allow you to place modules at a longer distance from your Gadgeteer-compatible mainboard, for hardware applications which don’t have precise timing requirements. Ferrites, shielding, and “every other conductor as ground” strategies may also provide advantages, as you excellently recommended.
Chris
Good suggestion Chris about the diff driver. I’ve used them (opto-isolating) on many occasions so maybe I’ll put a Gadgeteer one out there as a contribution.
I just ordered my Spider kit today!
There is a thread here somewhere where someone drew one of these up and I thought they were going to make some. Anyone know what happened to that?
Taking into consideration that was said above, the best way at the moment to keep module further from board is to use more Extender Modules and cables? (for example 10 meters)
Or there’s some alternatives?
@ Zaborius - what are you trying to extend to that distance? lots of ways to do it, but best depends upon your specifics.
For example i need to measure moisture in in different parts of garden… Or maybe keep camera further then 1 meter.
@ Zaborius - the moisture module, which requires an A socket, for analog input, should work at 10m, using so a wire like cat 5 and two extender modules. it might be a little noisy, but with a little software filtering it should work. also depends upon dynamic range of sensor. if range is very small might have problems.
you would not be able to extend a camera which used a H socket. a camera which uses a U socket might work, but again noise and the distance might be too much.
best way to tell is experimentation.
Oh! Great! Thanks, Mike.
