Don’t forget to look carefully at the antenna configuration.
A very high gain antenna on your base station will help enormously. When you pick a radio try to consider the availiability of cheap antennas. Anything around mobile phone frequencies or WiFi will be cheap and commonplace.
Also any additional height will make a massive difference.
If you need a propagation model to make some predictions then try Okumura Hats. That’s designed for exactly this kind of link. There are some online and phone app based tools, but it’s pretty easy to put the formula into a spreadsheet and roll your own.
Beware the range specs in the datasheets. Generally these are quoted in the absolute best line of sight cases. Look at sensitivity figures if they are availiable. Other factors such as other in band signals can cause degradation or blocking.
I’ll add that this LoRa modules look ideal. As they say the 900MHz signal is good for penatrating buildings and has much less interference than 2.4ghz.
Also there are plenty of good high gain antennas availiable.
