Word to the wise: If you run the GHI wifi example (or use certain Click boards), and your board suddenly locks up or otherwise acts wacky, it’s probably because your USB interface is not supplying enough current. With wifi and hungry click boards, you may need to use a powered hub or dedicated USB-C supply.
Source: me trying to get it to work on an unpowered usb hub.
