ok … I give up how do I load a jpeg from the file system? I know how to do from a resource but I want to load it from a SD card or USB. (I know how to do it in full wpf and in the full framework, but can’t anything in the micro framework.)
-Eric
-Eric
I think the only way is to read the file into RAM then construct a Bitmap object from your data
I have a pretty good example that illustrates this: http://files.chrisseto.com/UXL
Look in the extended weather info file.
Here is the code that use both image from resource and from SD card.
If you want to use jpeg just change type to be Jpeg
Bitmap artImage = new Bitmap(data, Bitmap.BitmapImageType.Bmp);
using System.IO;
using Microsoft.SPOT.IO;
using Microsoft.SPOT.Input;
namespace FEZ_Cobra_Window_Application1
public class Program : Microsoft.SPOT.Application
// SD Card is inserted
// Create a new storage device
PersistentStorage sdPS = new PersistentStorage("SD");
// Mount the file system
sdPS.MountFileSystem();
Program myApplication = new Program();
Window mainWindow = myApplication.CreateWindow();
// Create the object that configures the GPIO pins to buttons.
GPIOButtonInputProvider inputProvider = new GPIOButtonInputProvider(null);
// Start the application
myApplication.Run(mainWindow);
// Unmount
sdPS.UnmountFileSystem();
private Window mainWindow;
public Window CreateWindow()
// Create a window object and set its size to the
// size of the display.
mainWindow = new Window();
mainWindow.Height = SystemMetrics.ScreenHeight;
mainWindow.Width = SystemMetrics.ScreenWidth;
Panel panel01 = new Panel();
Image backgnd = new Image(Resources.GetBitmap(Resources.BitmapResources.MorningSky01));
backgnd.HorizontalAlignment = HorizontalAlignment.Center;
backgnd.VerticalAlignment = VerticalAlignment.Center;
//mainWindow.Child = backgnd;
panel01.Children.Add(backgnd);
FileStream fileHandle = new FileStream(rootDirectory + @ "\matisse001.bmp",
FileMode.Open, FileAccess.Read);
// Create the byte array to hold the data
byte[] data = new byte[fileHandle.Length];
// Copy file to byte array
fileHandle.Read(data, 0, data.Length);
// finished!
fileHandle.Close();
Image testArt = new Image(artImage);
testArt.HorizontalAlignment = HorizontalAlignment.Center;
testArt.VerticalAlignment = VerticalAlignment.Center;
panel01.Children.Add(testArt);
#region Display Text on the screen
// Create a single text control.
Text text = new Text();
text.Font = Resources.GetFont(Resources.FontResources.small);
// use text that store in resource as String1
text.ForeColor = Colors.White;
text.TextContent = Resources.GetString(Resources.StringResources.String1);
text.HorizontalAlignment = Microsoft.SPOT.Presentation.HorizontalAlignment.Center;
text.VerticalAlignment = Microsoft.SPOT.Presentation.VerticalAlignment.Center;
// Add the text control to the window.
panel01.Children.Add(text);
//mainWindow.Child = text;
#endregion Display Text on the screen
// Connect the button handler to all of the buttons.
//mainWindow.AddHandler(Buttons.ButtonUpEvent, new RoutedEventHandler(OnButtonUp), false);
// add the text control to the window
mainWindow.Child = panel01;
// Set the window visibility to visible.
mainWindow.Visibility = Visibility.Visible;
// Attach the button focus to the window.
Buttons.Focus(mainWindow);
return mainWindow;
private void OnButtonUp(object sender, RoutedEventArgs evt)
ButtonEventArgs e = (ButtonEventArgs)evt;
// Print the button code to the Visual Studio output window.
Debug.Print(e.Button.ToString());
enjoys,
sam
Sam,
Thanks! This is what I was looking for exactly:
// finished!
fileHandle.Close();
I had seen the constructor for Bitmap, but didn’t investigate because I was looking for something that took a filename or a stream.
Thanks again
-Eric
EricM:
Glad that helped!
sam
I wrote a digital picture frame app with the info and I’ll be posting it to the Wiki soon. (Along with a full framework app for sizing images to the appropriate size for display by the Cobra or the Chipworkx displays.)
Went together really quickly.
-Eric
