I’m trying to get this driver for a Nokia knock-off with a PCD8544 controller working for my kids to play with. I found a driver that works for the netduino and I’m having a heck of a time porting it to Domino for some odd reason.
Pin out (LCD/Domino)
1 VCC - VBAT
2 GND - GND
3 SCE - IO9
4 RESET - IO10
5 D/C - IO8
6 SDIN - IO11 (SPI MOSI)
7 SCLK - IO13 (SPI SCK)
8 LED+ - IO6 (PWM6)
Program:
private static Cpu.Pin RESET_PIN = Cpu.Pin.GPIO_Pin10;
private static Cpu.Pin CS_PIN = Cpu.Pin.GPIO_Pin9;
private static Cpu.Pin DC_PIN = Cpu.Pin.GPIO_Pin8;
Nokia_5110 LCD = new Nokia_5110(CS_PIN, PWM.Pin.PWM6, RESET_PIN, DC_PIN);
LCD.BacklightBrightness = 100;
LCD.DrawPoint(40, 40, true);
LCD.DrawLine(0, 0, 48, 48, true);
System.Threading.Thread.Sleep(-1);
Class:
public class Nokia_5110
private OutputPort reset, dataMode;
private PWM backlight;
private SPI spi;
public byte[] ByteMap = new byte[504];
private uint _backlightVal = 0;
private bool _invd = false;
public Nokia_5110(Cpu.Pin latch, PWM.Pin backlight, Cpu.Pin reset, Cpu.Pin dataCommand)
SPI.Configuration spiConfiguration = new SPI.Configuration(
latch, // chip select port
false, // IC is accessed when chip select is low
0, // setup time 1 ms
0, // hold chip select 1 ms after transfer
false, // clock line is low if device is not selected
true, // data is sampled at leading edge of clock
4000, // clockrate is 15 MHz
SPI.SPI_module.SPI1 // use first SPI bus
spi = new SPI(spiConfiguration);
this.backlight = new PWM(backlight);
this.reset = new OutputPort(reset, true);
this.dataMode = new OutputPort(dataCommand, true);
Initialize();
private void Initialize()
reset.Write(false);
reset.Write(true);
dataMode.Write(false);
spi.Write(new byte[] { 0x21, 0xBF, 0x04, 0x14, 0x0C, 0x20, 0x0C });
dataMode.Write(true);
Clear();
Refresh();
//public void WriteText(string text, bool noSpace = true)
// if (noSpace)
// foreach (char c in text.ToCharArray())
// spi.Write(ASCII[c - 0x20]);
// else
// byte[] letter = new byte[6];
// for (int i = 0; i < 5; i++)
// letter[i] = ASCII[c - 0x20][i];
// letter[5] = 0x00;
// spi.Write(letter);
public bool DrawPoint(short x, short y, bool on)
if (x < 0 || x >= 84 || y < 0 || y >= 48)
return true; // out of the range! return true to indicate failure.
ushort index = (ushort)((x % 84) + (int)(y * 0.125) * 84);
byte bitMask = (byte)(1 << (y % 8));
if (on)
ByteMap[index] |= bitMask;
ByteMap[index] &= (byte)~bitMask;
return false; // all is good (false = no error), return false to continue
public void DrawLine(short x1, short y1, short x2, short y2, bool on)
// This is a common line drawing algorithm. Read about it here:
// http://en.wikipedia.org/wiki/Bresenham's_line_algorithm
short sx = (x1 < x2) ? sx = 1 : sx = -1;
short sy = (y1 < y2) ? sy = 1 : sy = -1;
short dx = (short)((x2 > x1) ? x2 - x1 : x1 - x2);
short dy = (short)((y2 > x1) ? y2 - y1 : y1 - y2);
float err = dx - dy, e2;
// if there is an error with drawing a point or the line is finished get out of the loop!
while (!((x1 == x2 && y1 == y2) || DrawPoint(x1, y1, on)))
e2 = 2 * err;
if (e2 > -dy)
err -= dy;
x1 += sx;
if (e2 < dx)
err += dx;
y1 += sy;
public void DrawRectangle(short X, short Y, short width, short height, bool on, bool filled)
// this is easier to do with points instead of lines since the line algorithm isn't that great.
// this is only best to do with points because its straight lines.
short xe = (short)(X + width);
short ye = (short)(Y + height);
if (filled)
for (short y = Y; y != ye; y++)
for (short x = X; x != xe; x++)
DrawPoint(x, y, on);
xe -= 1;
ye -= 1;
DrawPoint(x, Y, on);
for (short x = X; x <= xe; x++)
DrawPoint(x, ye, on);
DrawPoint(X, y, on);
for (short y = Y; y <= ye; y++)
DrawPoint(xe, y, on);
public void Refresh()
spi.Write(ByteMap);
public void Clear()
spi.Write(new byte[] { 0x80, 0x40 });
private void Inverse(bool inverse)
_invd = inverse;
spi.Write(inverse ? new byte[] { 0x0D } : new byte[] { 0x0C });
public bool InverseColors
get { return _invd; }
set { Inverse(value); }
public uint BacklightBrightness
get
{ return _backlightVal; }
set
if (value > 100)
value = 100;
//backlight.SetDutyCycle(value);
backlight.Set(72000, (byte)value);
_backlightVal = 100;
Original Code: [url]LCD Help needed, 16x2s are boring - Netduino 2 (and Netduino 1) - Netduino Forums
