unless someone has figured out how to communicate with HID’s trough the serial port it wont work. you could put a PS/2 keyboard plug on it and “talk” to it on digital pins, but i’m not sure if you will get the timing right with netMF. specs for PS/2 keyboards are here: http://www.beyondlogic.org/keyboard/keybrd.htm
i tried http://code.tinyclr.com/project/191/telnet-type-class-for-netmf/ and when connecting Panda to my PC, it recognizes it as two devices named as, USBizi and CDC VCom. And drivers cannot installing successfully. Now i cant do anything with my panda
Please help me Is this problem cause of my PC or Panda? What can i do?
Thnx.
And Architect, i also know your link about mp3 player.
I tried various of codes to implement this. But my deployment device is USB. I dont have a RS232 device. I want to deploy and use same serial port on Panda II.
hi again, i tried to use another computer but problem didnt solved. When i connect panda to PC, there are 2 unknown drivers in the Device Manager named USBizi and CDC VCOM
Please masters. Help me to solve this issue How can i convert it to factory default or something else ?
i tried pushing LDR and then connecting to PC but PC didnt recognized the device. Because of nothing in USB section in MFDeploy, i cant update firmware.
Regards.
thanks for your answer. I downloaded the ghi 32bit drivers from the site. Uninstalled the current driver and reistalled. But after reinstalling the driver and connecting, again there are two different drivers with unknown. Problem didnt solved yet. If i buy a rs232 to debug on serial and erase the program, can u guarentee that it will be solved? I dont want to buy a panda ii for this issue yet.
this is solvable without added expense - thats what these devices are about.
The fact that you have devices that do not have drivers means you need to work to resolve that. You have told us nothing about your PC, whether it’s Windows 7 or not? Post us some pictures of what you see in Device Manager and what you did when you said you uninstalled / reinstalled the drivers so we can assist with the troubleshooting of that.
