I have a problem with List<T>.AddRange(T[]). It happens to add the wrong values. Given a specific test, it looks like a bug. I initially thought it was about the enum of type byte, but it seems that the same happens with int, not only enums.
I solved by using Add in a loop.
I’m using the latest 3.0.2.2000.
Follows the code of the test and the relative output:
private enum SampleEnum { Red, Green, Blue }
protected string EnumCopySelfTest()
string log = string.Empty;
SampleEnum expected = SampleEnum.Green;
// AddRange from an array
List<SampleEnum> copied = new List<SampleEnum>();
copied.AddRange(new SampleEnum[] { SampleEnum.Green });
log = Check(log, "AddRange(array)[0] == const", copied[0] == expected);
// copy element by element
SampleEnum[] array = new SampleEnum[] { SampleEnum.Green };
List<SampleEnum> copiedByAdd = new List<SampleEnum>();
for (int k = 0; k < array.Length; k++)
copiedByAdd.Add(array[k]);
log = Check(log, "Add loop[0] == const", copiedByAdd[0] == expected);
// AddRange from a List<T>
List<SampleEnum> source = new List<SampleEnum>();
source.Add(SampleEnum.Green);
List<SampleEnum> copiedFromList = new List<SampleEnum>();
copiedFromList.AddRange(source);
log = Check(log, "AddRange(List)[0] == const", copiedFromList[0] == expected);
// AddRange from an int array (not an enum)
List<int> copiedInts = new List<int>();
copiedInts.AddRange(new int[] { 17 });
log = Check(log, "int AddRange(array)[0] == 17", copiedInts[0] == 17);
return log;
private static string Check(string log, string name, bool ok)
string line = (ok ? "PASS " : "FAIL ") + name;
Trace.WriteLine("SELFTEST " + line);
return log + line + "\r\n";
Output:
SELFTEST FAIL AddRange(array)[0] == const
SELFTEST PASS Add loop[0] == const
SELFTEST PASS AddRange(List)[0] == const
SELFTEST FAIL int AddRange(array)[0] == 17
