Hi Sydcnky, welcome to the forums.
For the code you pointed to, it assumes the camera is connected to COM1.
That means connecting the COM1OUT line to the RX line on the camera, the COM1IN to the TX of the camera, and then power and GND. Since the camera is advertised as 5v (well sparkfun mention don’t trying 3v3; YMMV) you need to connect the power pin of the camera to 5v not 3v3.
Of course you could always change the COM1 in code and connect it to COM2, COM3, or COM4 if you wanted to. Your choice. Just remember that RX on the camera connects to TX or OUT on Fez, and TX on camera connects to RX or IN on Fez.
I m newer and not very similir to the these stuffs so don’t know what should i do to get a picture with Fez and camera.
My aim is to get the pixels of the picture and than have some image processing,but not on computer i 'm trying to make a robot with using this.
Is this code i’ve pointed to before stocking the picture to the SD card? Or how can i stock it to an SD card with this code ?
I did everything like you said and how i should do. Nothing seems wrong.
But,still always getting the error message " An error occured,please check your hardware"
Everytime i get this msg and cant fix it.
Can you help me please ?
Edit:
Incrementally deploying assemblies to device
Deploying assemblies for a total size of 238568 bytes
Assemblies not successfully deployed to device.
Deployment to the device was not successful.
