I would like to ask a question about the output signal “TX” from the MSC-MOD20.
What kind of output level is the TX signal after reset until the banner is output? (High-Z or weak-pull up/down?)
When measuring the TX pin with an oscilloscope, the level is low during this period.
This level also goes low when you touch the TX pin with my finger.
I would like to set this period to High level, and please answer if is there any good way.
By the way, the conditions are as follows.
Directly connected to TX of MSC-MOD20 and input pin of FPGA (Xilix Kintex 7).
The input pin of FPGA gives the attribute of weak pull-up.
The waveform is measured with a Tektronics oscilloscope.
This story is not about “ALFAT”, but about STM32. Ask on the STM32 forum.
This forum is suitable for talking about ALFAT “software”, but I think you should use stmicro’s forum as a STM32 questions that depend on the hardware specifications.
ALFAT is a monster of a SM32F205RBT6.
Before asking a question here, first do some experimenting with connecting a resistor.
Anything not mentioned in the ALFAT or STM32 data sheet cannot be solved by asking here.
You need to experiment and solve it yourself.
