I noticed yesterday that if I left my application on the Spider 2 running for 10-20 minutes I would eventually get an ‘Out of memory’ error. I bypassed most of the code and selectively enabled section after section while watching the GC dump in the debug window. The memory leak shows up as the amount of memory used growing by 3-4K between each GC dump.
After a few hours of enabling more sections of code and monitoring memory usage I found the issue was with the method that decodes the incoming packets (passed as strings). I have pasted the code below as you can see it has been modified a bit to let it run without the line marked //*** The memory leak is here ***///. I let this run all night and the memory usage stayed within a few K range. Perhaps the issue is how I’m passing data to my ‘getInt’ method? The problem is not immediately clear to me.
/// <summary>
/// Deocde RXd data packet, update local values
/// We read everything as strings
/// </summary>
/// <param name="packet"></param>
/// <returns>True if good packet</returns>
// Decode Tx packet from Mach 4
// axis positions -> ":M0=f:M1=f:M2=f:M3=f:" -> machAxisPos
// outputs -> ":O0=b:O1=b;O2=b...O7=b:" -> machOutputs
// (0-3 output) general -> ":G0=b:G1=b:G2=b:G3=b:" -> machGeneral
private bool decodeRXpacket(string packet)
bool value = false;
int lastDelim = packet.LastIndexOf(':');
string dataSt = packet.Substring(0, lastDelim); // trim ending delim
uint crc = uint.Parse(packet.Substring(lastDelim + 1, packet.Length - lastDelim - 1));
//uint crc32 = GHI.Utilities.Crc.Crc32(Encoding.UTF8.GetBytes(dataSt), 0);
// error if does not start/end with ':'
//if (packet[0] == ':' && packet[packet.Length - 1] == ':')
// if (crc == crc32)
if (true)
value = true;
string[] data = packet.Split(':');
foreach (string word in data)
if (word.Length > 3) // a valid word has to have at least 4 characters
string[] nameValue = word.Split('=');
char nameType = nameValue[0][0];
int nameIndex = 0;//int.Parse(nameValue[0].Substring(1, nameValue[0].Length-1));
//*** The memory leak is in this line ***//
//bool valOK = getInt(nameValue[0].Substring(1, nameValue[0].Length - 1), ref nameIndex);
//if (valOK)
if (true)
if (nameType == 'M' && (nameIndex >= 0 && nameIndex < 8))
// handles machAxisPos
machAxisPos[nameIndex] = nameValue[1];
else if (nameType == 'O' && (nameIndex >= 0 && nameIndex < 8))
// handles machOutputs
machOutputs[nameIndex] = nameValue[1];
else if (nameType == 'G' && (nameIndex >= 0 && nameIndex < 4))
// handles machGeneral
machGeneral[nameIndex] = nameValue[1];
return value;
/// <summary>
/// Helper to parse string to int and catch errors
/// </summary>
/// <param name="sValue">string to parse</param>
/// <param name="iValue">ref to int result </param>
/// <returns>True if no erros</returns>
private bool getInt(string sValue, ref int iValue )
try
iValue = int.Parse(sValue);
return true;
catch
return false;
