first of all thanks for the new update!
Keep up the good work…
But I dont want to be a spoilsport, but my led is still GreenBlueSwapped…
Im pretty sure i got the new dll, because the method SwapGreenBlue is missing.
There is a new property GreenBlueSwapped, if I set it to true everything works.
Mine is false…
And I have to set it manually to true for the LED to work properly…
I remove the LED from the Project and start all over again…
Maybe that helps
I have another question regarding to the source code.
Is there one solution that holds all the projects, or are they all seperated?
I checked out the code, but werent able to find the piece of software that glues all components together…
I checked out the gadgeteer source, and tried to find any usage of the GreenBlueSwapped property,
but I found only internal usage with no setting of that value.
But Gus told me that his value of this property is true, so there must be an external component setting his value from false to true that I cant find.
And Im searching for that component or piece of code that sets that value.
