We are building a PCB using the G120 chip, and got a question about the LDR0 and LDR1 pins.
Can I safely join the two pins together, let them float (no pullup to high) ?
And when I would need to upgrade the firmware, I ground them both together (using a pushbutton switch for example)?
The reason why is that we just want to expose a single switch outside the enclosure when a firmware update is necessary.
I already tested the method and it works with the G120HDR, but just want to confirm if it’s an OK solution or if it’s hack that may or may not work in the future.
I think it is alright. Not recommended but in worst case you can enter GHI loader, load tinybooter only without firmware and run teh device. IT will boot in tinybooter
Hey just to say that so far the solution works.
I press the LDR0+LDR1 as a single switch, reboot the device (either reset or plug and unplug) and I can update the firmware.
This is on our new custom board using the G120.
Thanks!
