I’m scaling down a project from a Chipworkx device to a Fez Panda II but I’d like to keep having a screen, even if it’s not as good as the Chipworkx, which is great ;D.
I cant see any problems with using that LCD. Its just a serial interfaced display, and to a great price. I have used this backpack a lot and get some cheap LCD of eBay. http://www.sparkfun.com/products/258
I’m using that LCD on a Domino without issue. Same code should run on a Panda II (once I get the new SDK on mine ;)) Just to be clear, all you can send it are chars/strings, and you can only see 2 lines of 16 chars each at a time. It does not do ‘graphics’ per se, but you can get some interesting results using non standard character sets. Some symbols will display, some won’t. If you just need a text display, you can’t beat the price.
