Hi, I have just received my Domino and LCD Keypad (red board). I have updated to the latest firmware (v4.1) and started a project in VS2010. No problems following instructions up to here.
I wrote a small app to test that the LCD was working (see attached file). It is compiled with FEZ_Shield_KeypadLCD_Red.cs in the project. The LED flashes correctly and I can turn the LCD backlight on and off but no text appears. I have tried adjusting the contrast but to no avail.
What next?
namespace FEZ_Project1
OutputPort LED;
LED = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.LED, true); //Thread.Sleep(Timeout.Infinite);
for (int i = 0; i < 5; i++)
LED.Write(true);
Thread.Sleep(200);
LED.Write(false);
Thread.Sleep(200);
FEZ_Shields.KeypadLCD.Initialize();
FEZ_Shields.KeypadLCD.TurnBacklightOn();
//FEZ_Shields.KeypadLCD.CursorHome();
FEZ_Shields.KeypadLCD.SetCursor(0, 0);
FEZ_Shields.KeypadLCD.Print(“Welcome 0!”);
FEZ_Shields.KeypadLCD.SetCursor(1, 0);
FEZ_Shields.KeypadLCD.Print(“Welcome 1!”);
first, please use the code highlighting. You can use it by clicking the code button above (the one with the 101010)
next, try the example code, does this work? Your code is a little messy, so please try the example code first.
Here it is:
int i = 0;
FEZ_Shields.KeypadLCD.Print("Count " + i++);
FEZ_Shields.KeypadLCD.SetCursor(1, 2);
switch (FEZ_Shields.KeypadLCD.GetKey())
case FEZ_Shields.KeypadLCD.Keys.Up:
FEZ_Shields.KeypadLCD.Print("Up ");
break;
case FEZ_Shields.KeypadLCD.Keys.Down:
FEZ_Shields.KeypadLCD.Print("Down ");
break;
case FEZ_Shields.KeypadLCD.Keys.Left:
FEZ_Shields.KeypadLCD.Print("Left ");
break;
case FEZ_Shields.KeypadLCD.Keys.Right:
FEZ_Shields.KeypadLCD.Print("Right ");
break;
case FEZ_Shields.KeypadLCD.Keys.Select:
FEZ_Shields.KeypadLCD.Print("Select");
break;
case FEZ_Shields.KeypadLCD.Keys.None:
FEZ_Shields.KeypadLCD.Print(" ");
break;
Thread.Sleep(100);
