I have adapted the C# program from GHI to take a single picture on a button press. It works once, then when I press the button a second time nothing happens at all!
This is the code I have adapted:
Imports System
Imports System.Collections
Imports System.Threading
Imports Microsoft.SPOT
Imports Microsoft.SPOT.Presentation
Imports Microsoft.SPOT.Presentation.Controls
Imports Microsoft.SPOT.Presentation.Media
Imports Microsoft.SPOT.Touch
Imports Gadgeteer.Networking
Imports GT = Gadgeteer
Imports GTM = Gadgeteer.Modules
Imports Gadgeteer.Modules.GHIElectronics
Namespace serial_camera
Partial Public Class Program
Dim LCD As Bitmap
Dim cnt As Integer
Dim font As Font
' This is run when the mainboard is powered up or reset.
Public Sub ProgramStarted()
font = Resources.GetFont(Resources.FontResources.NinaB)
' serCam.SetImageSize(Gadgeteer.Modules.GHIElectronics.SerCam.Camera_Resolution.SIZE_QQVGA)
oledDisplay.SimpleGraphics.AutoRedraw = True
Debug.Print("Program Started")
oledDisplay.SimpleGraphics.DisplayText("test", font, GT.Color.Blue, 30, 50)
Thread.Sleep(2000)
oledDisplay.SimpleGraphics.Clear()
LCD = New Bitmap(SystemMetrics.ScreenWidth, SystemMetrics.ScreenHeight)
cnt = 0
End Sub
Sub VideoStreaming()
serCam.StartStreaming()
LCD.Clear()
While (True)
Thread.Sleep(30)
If (serCam.isNewImageReady) Then
serCam.DrawImage(LCD, 0, 0, SystemMetrics.ScreenWidth, SystemMetrics.ScreenWidth)
oledDisplay.SimpleGraphics.DisplayImage(LCD, 0, 0)
serCam.StopStreaming()
'cnt = cnt + 1
' If cnt > 1 Then
'serCam.StopStreaming()
' serCam.StartStreaming()
' oledDisplay.SimpleGraphics.Clear()
' End If
End If
End While
End Sub
Private Sub button_ButtonPressed(sender As Button, state As Button.ButtonState) Handles button.ButtonPressed
serCam.isNewImageReady = True
Call VideoStreaming()
End Sub
End Class
End Namespace
As I say it works fine once. The “test” display comes up and goes, the screen waits for the button, it then takes and displays a single frame (from the camera) but when the button is pressed again nothing happens.
(PS I am using the L1 serial camera and a Fez Hydra on VB2012)
Hi Skewworks that has worked great thanks. One final question when I take the first image it displays fine, then when I press it again the image on the OLED is all stripy and messy - please see attached image. Is it the program or is my OLED display hardware playing up?
The driver is not very smart and I believe your passing an image that is not exactly 128x128 which will mess up following writes. To correct reset OLED between flushes or size image perfectly.
I have been using oled display.simplegraphics.clear() and it doesn’t seem to be completely flushing/clearing/wiping (whatever word you want to use!), it appears to overlay next graphic on the top or just make the screen all stripy as in the attached picture. Is there a way to actually restart the screen or do a proper clear?
Imports System
Dim LCD As Bitmap
Dim cnt As Integer
Dim font As Font
Thread.Sleep(2000)
cnt = 0
End Sub
LCD.Clear()
While (True)
Thread.Sleep(100)
cnt = cnt + 1
If cnt Mod 10 = 0 Then
End If
Exit While
End If
End While
End Sub
Thread.Sleep(1000)
End Sub
End Class
End Namespace
1.
using System.Collections;
System.Threading;.
using Microsoft.SPOT.Presentation;.
using Microsoft.SPOT.Presentation.Controls.
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;.
using GT = Gadgeteer;
namespace EMX_TestSerCam_4250
public partial class Program
new Thread(VideoStreamming).Start();
static Bitmap LCD = new Bitmap(SystemMetrics.ScreenWidth, SystemMetrics.ScreenHeight);
int cnt = 0;
void VideoStreamming()
serCam.StartStreaming();
LCD.Clear();
Thread.Sleep(100);
if (serCam.isNewImageReady)
serCam.DrawImage(LCD, 0, 0, SystemMetrics.ScreenWidth, SystemMetrics.ScreenHeight);
display_T35.SimpleGraphics.DisplayImage(LCD, 0, 0);
cnt++;
if (cnt % 10 == 0)
serCam.StopStreaming();
display_T35.SimpleGraphics.Clear();
Again it takes the first image after rebooting perfectly, fits it to the OLED perfectly, then when you press the button again the screen clears and this time the image is like the attached image. I can tell the new image is just that new because if you move the camera between shots you can make out that it is a new image not just a mixture of both images.
But like I say if you use the reset button on the board it then will restart and take the first image no problem…
I still can’t get it to sync properly after the first image. Does anyone have any ideas? I have tried changing the thread timings and the call but I cant seem to get it to do more than take the first image.
Take out the screen aspects, write to a file. Then see if the two captures are still the same.
Then, I’d restructure the While(true) and not rely on the Exit While.
Then, I’d ask, why do you stop streaming then start streaming again; the second time through that routine, streaming in theory would be running, so is that related to your error?
