Until the SDK comes out, you can use the following.
using GT = Gadgeteer;
using GTI = Gadgeteer.Interfaces;
namespace Gadgeteer.Modules.GHIElectronics
/// <summary>
/// A Keypad KP16 module for Microsoft .NET Gadgeteer
/// </summary>
public class Keypad_KP16 : GTM.Module
private GTI.DigitalOutput out1;
private GTI.DigitalOutput out2;
private GTI.DigitalInput in1;
private GTI.DigitalInput in2;
private GTI.DigitalInput in3;
private GTI.DigitalInput in4;
/// <summary>Constructs a new instance.</summary>
/// <param name="socketNumber">The socket that this module is plugged in to.</param>
public Keypad_KP16(int socketNumber)
Socket socket = Socket.GetSocket(socketNumber, true, this, null);
socket.EnsureTypeIsSupported('Y', this);
this.out1 = new GT.Interfaces.DigitalOutput(socket, GT.Socket.Pin.Three, true, null);
this.out2 = new GT.Interfaces.DigitalOutput(socket, GT.Socket.Pin.Four, true, null);
this.in1 = new GT.Interfaces.DigitalInput(socket, GT.Socket.Pin.Five, GT.Interfaces.GlitchFilterMode.Off, GT.Interfaces.ResistorMode.PullUp, null);
this.in2 = new GT.Interfaces.DigitalInput(socket, GT.Socket.Pin.Six, GT.Interfaces.GlitchFilterMode.Off, GT.Interfaces.ResistorMode.PullUp, null);
this.in3 = new GT.Interfaces.DigitalInput(socket, GT.Socket.Pin.Seven, GT.Interfaces.GlitchFilterMode.Off, GT.Interfaces.ResistorMode.PullUp, null);
this.in4 = new GT.Interfaces.DigitalInput(socket, GT.Socket.Pin.Eight, GT.Interfaces.GlitchFilterMode.Off, GT.Interfaces.ResistorMode.PullUp, null);
/// <summary>
/// The possible keys that can be pressed.
/// </summary>
public enum Key
/// <summary>
/// The A key.
/// </summary>
A,
/// <summary>
/// The B key.
/// </summary>
B,
/// <summary>
/// The C key.
/// </summary>
C,
/// <summary>
/// The D key.
/// </summary>
D,
/// <summary>
/// The # key.
/// </summary>
Pound,
/// <summary>
/// The * key.
/// </summary>
Star,
/// <summary>
/// The 0 key.
/// </summary>
Zero,
/// <summary>
/// The 1 key.
/// </summary>
One,
/// <summary>
/// The 2 key.
/// </summary>
Two,
/// <summary>
/// The 3 key.
/// </summary>
Three,
/// <summary>
/// The 4 key.
/// </summary>
Four,
/// <summary>
/// The 5 key.
/// </summary>
Five,
/// <summary>
/// The 6 key.
/// </summary>
Six,
/// <summary>
/// The 7 key.
/// </summary>
Seven,
/// <summary>
/// The 8 key.
/// </summary>
Eight,
/// <summary>
/// The 9 key.
/// </summary>
Nine,
/// <summary>
/// Determines whether or not a given key is pressed.
/// </summary>
/// <param name="key">The key whose state we want to check.</param>
/// <returns>Whether or not the key is pressed.</returns>
public bool IsKeyPressed(Key key)
bool out1 = false;
bool out2 = false;
if (key == Key.One || key == Key.Four || key == Key.Seven || key == Key.Star) { out1 = false; out2 = false; }
else if (key == Key.Two || key == Key.Five || key == Key.Eight || key == Key.Zero) { out1 = true; out2 = false; }
else if (key == Key.Three || key == Key.Six || key == Key.Nine || key == Key.Pound) { out1 = false; out2 = true; }
else if (key == Key.A || key == Key.B || key == Key.C || key == Key.D) { out1 = true; out2 = true; }
this.out1.Write(out1);
this.out2.Write(out2);
if (key == Key.One || key == Key.Two || key == Key.Three || key == Key.A) return !this.in1.Read();
else if (key == Key.Four || key == Key.Five || key == Key.Six || key == Key.B) return !this.in2.Read();
else if (key == Key.Seven || key == Key.Eight || key == Key.Nine || key == Key.C) return !this.in3.Read();
else if (key == Key.Star || key == Key.Zero || key == Key.Pound || key == Key.D) return !this.in4.Read();
return false;
