Here is a PC C# console app that includes the decoder and uses the same Key and example as found in the documentation http://www.ghielectronics.com/docs/49/xtea. I’ll be updating the documentation to include this decoder (as well as an encoder … as soon as I finish coding and testing it);
using System.Collections.Generic;
using System.Linq;
using System.Text;
namespace ConsoleApplication1
class Program
static void Main(string[] args){
byte[] key = new byte[] { 1, 2, 3, 4, 5, 6, 7, 8,
9, 10, 11, 12, 13, 14, 15, 16 };
byte[] eline = new byte[] {214,35,6,78,132,80,106,174,188,254,196,59,5,135,9,255 };
Console.WriteLine("hello world");
Console.ReadLine();
int length = 16;
byte[] decrypted_bytes = new byte[16];
Boolean result = Xtea.Decrypt(key,eline, decrypted_bytes,
eline.Length);
Console.WriteLine(result);
string decrypted_string =
new string(Encoding.UTF8.GetChars(decrypted_bytes));
Console.WriteLine(decrypted_string);
Console.ReadLine();
public static class Xtea
public static Boolean Decrypt(byte[] key, byte[] encryptedData, byte[] plainData, int dataSize)
if( (dataSize % 8) == 0)
if(dataSize != 0)
dataSize /= 8;
UInt32 i;
UInt32[] v = new UInt32[2];
UInt32 sum;
UInt32[] lkey = new UInt32[4];
int eoff = 0;
int poff = 0;
Buffer.BlockCopy(key,0,lkey,0,16);
const UInt32 delta = 0x9E3779B9;
while(dataSize-- !=0 )
Buffer.BlockCopy(encryptedData , eoff, v,0,8);
sum=0xC6EF3720;
for(i=0; i<32; i++)
v[1] -= (v[0] << 4 ^ v[0] >> 5) + v[0] ^ sum + lkey[sum>>11 & 3];
sum -= delta;
v[0] -= (v[1] << 4 ^ v[1] >> 5) + v[1] ^ sum + lkey[sum&3];
Buffer.BlockCopy(v,0,plainData,poff,8);
poff+=8;
eoff+=8;
return true;
return false;
