Yesterday, after installing the 4.2 beta on a Spider, I ran a quick test with the Matrix Led Module. My initial reaction was that the display was updating a lot slower than it did with the 4.1 SDK. On 4.1 the painting was almost instantaneous, while on 4.2 I could see each led getting updated.
This morning I ran some tests to verify/quantify what I though I was seeing. The results verified that the module is updating a lot slower in 4.2. In 4.1 the module updates in around 19+ milliseconds, while it takes 113 milliseconds in 4.2.
I suspect that the daisy link is running at a much slower speed under 4.2.
This is the code I ran to test the performance of the module:
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace Tester42
public partial class Program
private byte[] clear = new byte[8] { 0, 0, 0, 0, 0, 0, 0, 0 };
private byte[] allOn = new byte[8] { 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff };
private Thread thread = null;
button.ButtonPressed += new Button.ButtonEventHandler(button_ButtonPressed);
void button_ButtonPressed(Button sender, Button.ButtonState state)
thread = new Thread(_Run);
thread.Start();
private void _Run()
// calibrate loop
DateTime start = DateTime.Now;
for (int i = 0; i < 1000; i++)
TimeSpan elapsedLoop = DateTime.Now - start;
// do test
lEDMatrix.DrawBitmap(allOn);
TimeSpan elapsedTest = DateTime.Now - start - elapsedLoop;
Debug.Print(elapsedTest.ToString());
