baz
June 11, 2013, 6:33am
1
How can I create a JSON payload to upload to my Web server (I need to call a Web Api) from my Cerbuino?
System.Runtime.Serialization.Json?
the old FastloadMedia.NETMF.Http that I did use on my Panda?
Any GHI lib available somewhere in code base?
HughB
June 11, 2013, 6:38am
2
@ baz - there is a JSON project in the codeshare section https://www.ghielectronics.com/community/codeshare/entry/282 will that do what you need??
baz
June 11, 2013, 6:55am
3
This is FastloadMedia.NETMF.Http I’ve used on Panda.
I don’t know if I may use this (old) custom code, or if there is some integrated (more powerful) features in 2013 platforms that I can use…
HughB
June 11, 2013, 7:26am
4
This should still work, i havent used JSON myself but im sure if there is anything newer or better the US guys will know.
baz:
This depends on how you want to serialize, but its also quite simple to manually convert a class to JSON. Say your class contained two integers and a string.
public class JSONData
public int a = 0;
public int b = 5;
public string str = "Heres my string";
You could simply inject the data into a string, so that the formatting looks like this:
"data": [
"a": "0",
"b": "5",
"str": "Heresmystring"
This will create a Javascript array object named data, with fields ‘a’,‘b’, and ‘str’. A great validation tool can be found at http://jsonlint.com/
