Thanks for those links. I didn’t spot the XML 7 day format. I had the 1st one working and then wanted to add a 5 day forecast but only saw the JSON format. (4.3" limits me to 7 for readability)
@Dave_McLaughlin - I used openweathermap.org in my digital portal project. If you take a look at the WeatherProvider.cs class in the project below it uses JSON to process the “one call API”.
Thanks Tom. I’ll be uploading my project to github when it is complete. I’ll be sure to make sure any source used has the original name included.
I have a dual 4.3" LCD SITcore for this project with one display showing time and the other the weather include 2 sensors via MQTT at my house. They communicate with each other over CAN. 2 Fez Portals could be used to run the software on but I only have wifi on one board.
